squeal at startup? not a belt.... - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 10-01-2011, 02:09 PM
Gnarkle's Avatar
Gnarkle
Offline
Member's Gallery
Good morning PSN,
I have recently noticed on cold starts a quick squeal at start up. I assume it has something to do with my turbo, as it starts normally, but the turbo takes a few seconds to spool. It seems as soon as it squeals, the turbo starts spooling up.
Is this a big deal? turbo going south? once started, seems completely normal. I haven't checked for any play yet, going to do so today. truck has 150K on her.
As always, any insight is greatly appreciated!
Also, I have recently done a 4" turbo back exhaust and noticed a few more turbo farts than with the stock exhaust. Mostly when towing. Should i be alarmed?
Old 10-01-2011, 02:46 PM
Snake's Avatar
Snake
Offline
40 lug nuts
Member's Gallery
Re: squeal at startup? not a belt....
At a minimum, your turbo needs to be cleaned. More than likely it needs to be rebuilt or replaced.
__________________
BULLETPROOF DIESEL
Biofuels Technologies
2005 F-250
  #3
Old 10-01-2011, 06:53 PM
Gnarkle's Avatar
Gnarkle
Offline
Member's Gallery
Was planning on cleaning it out as soon as possible, hopefully its not toast!
  #4
Old 10-01-2011, 07:23 PM
RedDog's Avatar
RedDog
Offline
Member's Gallery
I have same problem with 04. It is an exhaust leak at the collectors off manifold into the y pipes or the metal gasket in between the right up and the left one.
  #5
Old 10-01-2011, 08:00 PM
Snake's Avatar
Snake
Offline
40 lug nuts
Member's Gallery
An exhaust leak would be an almost constant squeal, not just at start up.
  #6
Old 10-01-2011, 10:31 PM
RedDog's Avatar
RedDog
Offline
Member's Gallery
nope had an 04 that had a squeal at start up once stuff warmed up and expanded it didn't squeal. tightened the #### out of the y pipe bolts squeal went away.
  #7
Old 10-01-2011, 10:33 PM
RedDog's Avatar
RedDog
Offline
Member's Gallery
i am just trying to rule out quick and easy fixes people would never think a squeal would come from. i thought the bearings were toasted in turbo but turbine was loose with no tightness. fins did not hit housing.
  #8
Old 10-02-2011, 01:17 AM
Gnarkle's Avatar
Gnarkle
Offline
Member's Gallery
will try and snug them up tomorrow, thanks for the tip!!!
  #9
Old 10-02-2011, 03:33 AM
Cobra 19 & 54
Offline
Sarcastic Bastard
Member's Gallery
like this?
__________________
Innovative Diesel Performance Thanks Eric!
Direct Injection Performance - GoGoDiesel.Com, Your Source For All Things Diesel! Thanks Doug!
Special thanks to Rich for helping me pick chargers for my newest mod!!
  #10
Old 10-02-2011, 05:14 PM
Gnarkle's Avatar
Gnarkle
Offline
Member's Gallery
hmm, nope not quite. It starts up just fine and for about 5 seconds it sounds almost like a gasser then a quick high pitched squeal, and immediately after you hear the turbo hissing like normal.
That knock sounds rough!
(View-All Members who have read this thread : 55
04 oilburner, 05wh250, 06-sixoh, 1000klr, 1sd, 89fiveoh, 91forddiesel, 99STROKINSMOKIN, ajfetterman, baja5bss, Blue Hawg, bond james bond, Boost96, bustednuckles, cavscout075, Cobra 19 & 54, Dawgfan52, diesel78, DingleB, djl95, dp42, Dr C, eleventhtruck, Fever, Gnarkle, hdf3502005, Idahoser, jamcconnell2, jeromejcp, justintimemoto, keblmo, KingRanch05, mastrkee, mikes95powerstroke, nrook, Per4mance, poon, powerstruck7.3, Quadzilla500Dad, RedDog, Samson, SaNnDnSurF, scparrish, sesco4, shadow6.0, ShiftyCapone, Skier2880, Snake, Sndwrkr, sonnyy13n, sunsetmazdacs, toolmangary, Turd-250, Zmann
You may not post new threads
You may not post replies
Forum Jump
