| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
6637 mod: what can it support?
Can a simple 6637 filter support 500rwhp, or is it not gonna be able to flow enough air?
I ask because I can get the filter locally for $23 but if it wont work for my end goals i'll go straight to an intake system that can |
| Sponsored Links | |
Advertisement |
#2
Re: 6637 mod: what can it support?
I'll take a stab at it and say yes (depending on how you plumb it ... no PVC fittings!). The Donadson filter used in the Tymar setup can flow a lot of air. JMO though. Cheers!
__________________
97 F250 SC 4x4, E4OD, 4.10 LS, Basically Stock, Relocated Block Heater Plug, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV |
#3
There's not much more you can do to flow more air except...NO filter.....and you know the answer to that.....NO
__________________
2002 F-250 SD Lariat CC 4x4 7.3L automatic. Underdash gauge pod with ISSPRO gauges. Zoodad. AIH delete. DIY Tymar filter. Sonnax Kit. 4" turbo back straight exhaust and 4-6" Silverline chrome tip. 20" wheels with 32x12.5 Toyo MT's '08 aluminum rear diff cover. SOLID AXLE front cover. A/C Mod |
#4
Take a deep breath through a 6637. Feels like there is no restriction at all, like you were breathing normal... I had to try it when I got mine
__________________
1996 F-350 CCLB dually, 4.10, 235/85R-16, ZF5, Tymar intake, Alabama Flowmaster, Isspro gauges, TS chip, Tightwad Mod |
#5
Anyone know the specs of the 6637 filter?
I'm rather curious why its so much cheaper than the BHAF dodge guys use (napa 2790). Its half what the dodge filter is |
#6
Actually here is a more important question.
How close does the 6637 come to touching the hood/other surrounding objects? Because the 2790 filter is 1/2" shorter, but 2" fatter, and according to fleetfilter flows 680cfm vs 400 for the 6637 Both have the same 4" outlet |
#7
I like the looks and sound of the 2790. But I will have to go out and look, to see if it will fit in the same spot as a 6637.
That is a good increase in flow over the 6637 680 vs 425. That is a good increase.. On Edit: Here it is........Wix 42790 & Napa 2790 Air Filter: FleetFilter Secure Online Store And for comparision the 6637.............Wix 42790 & Napa 2790 Air Filter: FleetFilter Secure Online Store
__________________
97 7.3L F-350 single wheel, CC, LB, 4x4, 3.55 Gears, Lockers front and back, ZF6 transmission, 350/200 Sticks, 910 VS, ARP HS, Stealth Dual HPOP, |
#8
I don't think the other one will fit where the 6637 would go. Even if the hood closes, the larger diameter will probably be against something and restrict the flow (and negate any flow advantages). Cheers!
#9
I might just have to replace my 6637 soon than....I'm wanting to run a custom intake like the ATS Great White truck anyway.
Chad
__________________
![]() 00 F350, 08 clone, 3" cowl hood,billet grilles, 15" lift, 40" SS M16'S, 24X12 Rockstars, 2% tint, EBPV Delete, 4" duals w/7" tips, 6637 intake, WW, CCV Mod, PHP 80,120 race,140 Extreme, stage 1 single shots, 6.0 I/C Chad |
#10
I imagine if anything this would at least help with EGT's if you could fit it
| Thread Tools | |
| Display Modes | |
