7.3 Powerstroke Injector removal and install - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 08-31-2011, 01:15 AM
ascrap2003's Avatar
ascrap2003
Offline
Famous words "Watch This"
Member's Gallery
Finally got some injectors, well 4 anyway. Ryan Casserly Stockers
To start I removed the vc & gasket then removed the oil plug as seen below. Make sure the alen wrench is a snug fit. There are 2 of them one on left top of head & one on right, this beats purging the cylinders when done.
Next you gotta remove the oil spout bolt & two injector hold down bolts.
You gotta use a wrench for the bolt under the injector plug.
Focker in law took off with some of my tools so I used the open end of a 1 1/8 wrench to pry injectors worked pretty nice.
Next just remove injectors slowly "So that brass washer dont fall off" one at a time, now just install new injectors seating them with a rubber mallet & reverse the whole process.
Torque everything to spec.
__________________
2002 F350 SuperCab SWR Lariat, Hutch Mod, EBPV Delete, Down Pipe,
My websites:
Non Ferrous Metals Recycling
X-ray film recycling
Aircraft Engine Buyers
Old 08-31-2011, 02:06 AM
biggreen96's Avatar
biggreen96
Offline
Member's Gallery
Re: 7.3 Powerstroke Injector removal and install
Just fyi you only need to remove th bolt on the out side to remove injector.
__________________
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
  #3
Old 08-31-2011, 03:39 AM
ascrap2003's Avatar
ascrap2003
Offline
Member's Gallery
Outside? Ah ok I get you now!
  #4
Old 09-21-2011, 02:22 AM
Black_Clouds's Avatar
Black_Clouds
Offline
Member's Gallery
i removed my injectors and modded them and now i cant get my truck to start..i filled the hpop with oil and there is fuel in the bowl...any tricks to getting the air out quickly instead of just cranking?
__________________
96 F-250..5 speed,3.55,285/75/16 toyomt,ts 6 pos, DI tunes, 4 inch MBRP straight pipe,TYMAR intake,AFE Big Boost filter,129,xxx, Stroked A codes (stock nozzles for now) 15* HPOP,...coming soon.. custom turbo,t1000 or srp1,e fuel
  #5
Old 09-21-2011, 02:40 AM
jmsmith76
Offline
Member's Gallery
keep on crankin, it takes awhile. just let your starter cool between tries so you don't burn it up
__________________
-John-
1996 F-250 Ext Cab Long Bed 4x4 w/ a few mods
  #6
Old 09-21-2011, 04:27 AM
powerstroker66's Avatar
powerstroker66
Offline
Member's Gallery
i left the injectors unplugged and the glow plugs out then cranked it to build pressure and make it easyer on the starter. Then re-installed the glow plugs and pluged in the injectors and she fired over with in 2 15 second cranking cycles.
  #7
Old 09-21-2011, 03:08 PM
Bradbilt's Avatar
Bradbilt
Offline
STILL LEARNING
Member's Gallery
Good plan
__________________
97 CCSB 4WD 7.3 5spd DP Tuner, 6637, 4" Flo-Pro SS Exhaust(3" DP), 99 I/C, T500,Cali Truck w/120cc Split Shot Injectors, 1.0 exhaust housing/WW2, Irate Up-pipes, CCV Mod, Autometer gauges, Valair Organic clutch, PFM 2.25" RSK, PMF Traction bars, Rear Air bags,SD springs Front(V code)/rear(B code), 315/75/16s, 300HP/561TQ
  #8
Old 09-21-2011, 03:32 PM
OUTLAW101
Offline
Member's Gallery
All that does is purge the cylinders. I do however reccomend for everyone to do this. Taking out the oil galley plugs sometimes isn't enough IMO.
__________________
late 99 black CCSB
(View-All Members who have read this thread : 341
00 ford f250, 01 silver bullet, 01International7.3, 01pwrstkr, 02POWERSTROKE7.3, 03ranger30, 03_7.3POWER, 04blackcrewcab, 06KingRanch6.0L, 1978psd, 1SLO GT, 2000XLifted, 4duggan, 7.3 Blackout, 7.3 stroker10, 7.3EX, 7.3lsmoker, 73stroke99, 79Ford7.3, 7THREE, 89 Stroker, 91turbogsx, 94.5stroker, 94Matt, 94youngturbo, 95 smoker stroker, 95powersmoker, 96Crewcab7.3, 9773, 97Powerstroke Boy, 97Stroker13, 97supercab, 97XLT7.3, 99whitestroker, Adam.Niesen, alpipehand, Alvapowerchoke, arctic-20v, ArXane, ascrap2003, AZF350PS, babyjones, badblack01gt, BadDogPSD, bagels71, Balthasar, Beefy446, bfoster, Big Chuck, Big97fordpowerstroke, biggreen96, Bignbadbelair, bigwhite95, Black 02, Blackbullet73, blackstar, blackvr4, Black_Clouds, Blake8550, blane, BlindViper, BlkNTan, bluedevilslax, bmxanrchy127, bobbycollins, Boost96, boostaddict, borncountry, Boydog, bpa658, Bradbilt, brick, brock04gt, Browning, Bullitt#829, BURNSY_B_STROKIN, Bushwakd, camd94234, CanadianPS, ccf350stroker, Ceelock, Chadahootchie, cheap bronco, Choupique108, coalroller78, conman365, constF350, copeland1456, Copperhed, cory99, Critical, csilvers1984, cthom388, czangli7, d-selpowereddiebauer, danielzink, danimalmanimal, Dansk, Dasaliac03, dave jr, DaveBey, davidamontoya, Day-Day, Deererainman, Derek C, Diesel dummy, Dieselboy, DieselTiger, Dieslnevan2009, dizzy8085, djl95, DoableSalvage, dogmaticus, dragonboi, Drew2010, drh4250, dschack, dsinderson, dtott, Dwduggins, dyoung14, DzlNut, e.gresham, eastcoastevolutionjl, ElkBowHuntR, ericlouie1, Ethan218, f250towrig, F350fummims, farmboy17, Fire Mechanic, FL-R, FlatbedStroker, floridastroke, ford7.3sd, fordboy324, fordman73, fordnut, foxman, friskyjake, glasseater, glovemeister, Gone Huntin', gordo1384, grantw1221, greenbeast, greenmachine07, gsxr1216, Guynormal01, hellerb68, hendricksbus, Hijo202, Hoss1997, hwrdbd, ilh, iluv83vettes, Impulse138, internationalpsd, Iowa 73, iowacornfarmer, Ithumpwheniwalk, Jackson Dairy, jakes2000, JD3020, jerry k, jethro442, JGod, Jjona5, jkrum10238, Jlh, jmsmith76, John-Boy, johndeereman, jonstangnelson, jpstroke96, jrbrock, jrracerdad, jschildm, jtrk13, ju015dd, just shawn, justinlogue5_0, juvenile9, K5383, Kgaeta92, kip4234, klos, kramarj, kvn555, kyl1316, lght1, Lildiup, lilhixson, littlewoody, LoneStar7.3, Lord Humungus, loudmouth, m j, M8xpld, madpogue, maineboy11, maritimer10, markfuga, Matikus, Matt-F350, metrojd, mike t., mikes95powerstroke, milehighstroker, MILFORD, moco, mojoman, MoparNut-Gone-PowerStroke, mrit, msscatter, muztangFB, mwbuilds, my92issues, myloyambag, natetheace, NDPSD, NE-STROKE, Neal21, NEDEERHUNTER, Obspsd7.3, OBSWIZ, old Smokey, Onfirepowerstroke, opieg01, Otter70, OUTLAW101, pappa b's powerstroke, parne, Patrick Feeley, Patrolman, pc97f350, pdj4814, petermoblin, Petro, pff250hd, phercinger, pkcole, plowguy1225, Poh, ponypusher58, powersmoker73, Powerstoke_Fan, POwerstroke Named BIG D, POWERSTROKE2311, powerstroke29, PowerstrokeR00, powerstroker66, Powerstrokin96, Prozon, psd kid, PsRumors, pstrokin97, pungohboy, Pwnm30rdi3, rafter3w, rayd1969, rayrayray01, Red95stroker, reedi1, reptillikus, ridnskyhigh, RNally, rndllquinn, ROB240, Rocket Pig, Rocketnut, Rodknocker, Roenicke95stroker, rollingthunder, rolsmojave3, rorednick86, roughneck0913, rusty1161, Schofield1990, sdm, shoebear, sjdiesel, slowleak, slymjym350, smokee, sniperjms, SouthJerseyStroker, spike, steinerr, strokefreak, STROKENPA, STROKER #1, STROKERBO, strokertown, StrokeThis99, strokin1995, Strokin450, StrokinAces1973, StrokinSince97, Strokinstrong, TacticalMonk, tcwilson4, tecatehubbs, tella, TheHamm, THUNDERstroke73, tongboy, toolmangary, tractorman1365, travis182008, trimacwest, tubular031, TylerDurden, T_444_E, umpalumpa1985, USAF_EOD, venomusduck, walkerblayne, WannaRollCoal, water_junky, webb06, Why Not, wiblueboy, Wilson444, wilster734, WishinIwerFishin, woodsman, wvmike, wyrider, yavorssj, zarrinvz24, zilla68, ZOSO, Zrock, zusmc
You may not post new threads
You may not post replies
Forum Jump
