power plant questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > The Nation's Hangout > Sled Pulling
Thread Tools Display Modes
  #1
Old 08-01-2011, 07:03 PM
clueless
Offline
I like pie
Member's Gallery
I know the 7.3L is the preferred power plant of choice for most, but could somebody sneak by with a 6.0? The 7.3 is getting harder to find, and sometimes the 6.0 can be cheaper, but the question is, would this be a time to cut corners?
You may need a little back round information, I want to run in 2.6/hot street, and eventually make it to the 3.0 turbo class. The truck will be a dedicated puller seeing as I already have the spare truck now I just need the transmission and a worthy power plant.
Old 08-01-2011, 08:14 PM
countryboyrob's Avatar
countryboyrob
Offline
Ya'll are idiots
Member's Gallery
Re: power plant questions
I dont see why not, just as long as the work is done right I dont see why there would be a problem.
  #3
Old 08-02-2011, 12:52 PM
Bigsexy's Avatar
Bigsexy
Offline
Dan the diesel man
Member's Gallery
From what I've seen the 7.3 is a better pulling motor. Around here none of the built 6.0s have any luck, but I know there's guys kickin arse with 6.0s. Seems like there a lot of good solid parts out there to build a 7.3
__________________
1999.5 F250 cc, sb
Ts chip with Cales tunes, diy intake, 4in exhaust, gtp38r, full force stage 1 sticks, and a b.a. built tranny w/precision t.c..
  #4
Old 08-02-2011, 02:22 PM
RSieck's Avatar
RSieck
Offline
All Talk, No Walk?
Member's Gallery
Send a message via AIM to RSieck
With what we have to work with right now, HEUI ain't going to cut it in 3.0. Well maybe, depends where you're located. 2.6 is at least 750+, 3.0 1100+...
__________________
Early 99 PSD 4x4, Goerend Billet Tranny & Converter, GREEN
  #5
Old 08-02-2011, 03:03 PM
clueless
Offline
I like pie
Member's Gallery
Yes sir that's about right, for 3.0 (someday) I do plan on P-pumping it, but for 2.6 HEUI will do just fine for now.
I also live on the state line of Illinois and Indiana, on the Illinois side the 2.6 trucks are a little behind the Indiana trucks, but thats just what I have seen from pulling Pro4x4 for the past 20 years with the family (this may be a wrong observation)
Also, could some one put a longer stroke in the 6.0 to help with the cubic in displacement for the 2.6 class?
  #6
Old 08-03-2011, 02:24 AM
95f250psd's Avatar
95f250psd
Offline
Member's Gallery
elite maybe?
__________________
03 f250 6.0L livewire egr delete, sinister head gaskets arp head studs, air dog 2 4in procomp lift on 35s. 95 f250 7.3L 300k miles dp tuner gtp 38 burned up trans. 84 f350 crew cab rust bucket.
i seem to be really good at breaking parts and spending money on things i dont need
  #7
Old 08-03-2011, 05:28 AM
JD3020
Offline
Member's Gallery
Around here you could safely bump those numbers up a hundred or two. I'd say a 750hp truck would have a very hard time competing for the win here in 2.6. With shops like Danville, Haisley, and some others running around the few Fords get whooped on pretty hard. I'd say that until something big happens in the HEUI world they won't have a shot here.
Now as to what motor to use, i would go with a 7.3. With the limitations of the HEUI system you'll want all the displacement you can get. You also have the options of going with a mechanical pump, or CR(hopefully). Which i think that if Swamps can make the CR system work good on these 7.3's then IMO we will have a shot at being able to compete with the big dogs.
Which something i've also wanted to know is what kind of power these 2.6 trucks are putting down. Like the top D-max, Cummins, and 7.3's just to see how far behind we are. But unfortunately guys like to keep the dyno sheets to themselves.
__________________
1997 F-250 XLT 4wd ECLB. 187k miles
So far: lightweight body mod(aka rust), 120v IDM, 17* HPOP, Gearhead tunes, 175/100's and trans from Unlimited Diesel
Soon to come: less rust, traction bars
  #8
Old 08-03-2011, 04:54 PM
RSieck's Avatar
RSieck
Offline
All Talk, No Walk?
Member's Gallery
I'll echo what he says about going with the 7.3. Way more options to make more HP down the road when HEUI won't cut it anymore.
A 2.6 dodge here claims his pump was dynoed on a similarly built motor, and hit over 1000hp. But his truck sure don't run like it has 1000hp, but he did finish top 10 down at that big pull in Platte City, MO
  #9
Old 08-03-2011, 08:50 PM
clueless
Offline
I like pie
Member's Gallery
The only reason I was thinking about using the 6.0 is the availability of the engine. I can't get a hold of a 7.3 around here that hasn't been totally trashed. I would love to use the 7.3, but I really having a hard time finding one, if you see one floating around would you let me know?
  #10
Old 08-03-2011, 08:52 PM
Cobra 19 & 54
Offline
Sarcastic Bastard
Member's Gallery
You should check with doug at gogo.
__________________
Innovative Diesel Performance Thanks Eric!
Direct Injection Performance - GoGoDiesel.Com, Your Source For All Things Diesel! Thanks Doug!
Special thanks to Rich for helping me pick chargers for my newest mod!!
(View-All Members who have read this thread : 89
01stroker7.3, 04smokeman, 4duggan, 73smoker, 95f250psd, 95rdstroke, 96 stroker, 96powerstroker, 99f35012v, alwil, aomoore, BBottoms, BDS, bigfords, Bigsexy, BIGSKI15, Binderpower, biostroke1, birddog55, black_pstroke, bluovldeezl, boostaddict, caseih7010, Cloverleaffarm, clueless, Cobra 19 & 54, Comp7.3, corybens11, Dieselfever, Dieselholic, Dirty Curry Racing, dwall, Eford00, Farmall, Fearless Ford, FRMDSL, GMAN1, GOOSEKILLER, hendershot, IDP, JD3020, jsindlin, Jwagoner15, jwarren, K16 Common Rail, Kampy, kbog350, lossscause, MAXPWR, Millerfarms, mttrucker, mud on the tires7.3, Mustang06, NE-STROKE, NEBR99.5 OIL BURNER, oldbluef250, OldDirty, oregon96psd, ParkerFly, Petro, pontiacross, poon, powdersmoke4700, PowerstrokeJunkie, PrvnTough, rake18, rbwyatt, RSieck, Rudy's Diesel Performance, Rupp250, shadow6.0, silverf250, SLAMDS10, smokinstroker92, strokin533, strokintilbroken, superstroker99, threestud, tractorsny, tree trimmer, turboteeljr21, Tygen1, tylan, vader's fury, wicked_four_play, wjamesm
You may not post new threads
You may not post replies
Forum Jump
