97 f350 death wobble/hop - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 07-30-2011, 03:12 PM
corybens11
Offline
Member's Gallery
They guys! i am now a proud powerstroke owner! I just bought a 97 regular cab f350 with a shackle flip about 6" of lift on 37's. i had a problem the other day when i hit a couple bumps in the road at probably about 35 and it went nuts, the front started hopping really bad like you were driving on a washboard until i slowed down then it went away. Now One- i looked under it and there is no trac bar, two the 37s are fluid balanced. I would imagine i should start with a trac bar but idk how big of a drop bracket to get for the mount and where to get that and a trac bar. i jacked it up and the ball joints are tight but the leaf spring bushings look like they have had better days and thats pretty much all that keeps my axle from moving side to side right now. any help opinions or experience is appreciated! thanks
Old 07-30-2011, 04:42 PM
Bradbilt's Avatar
Bradbilt
Offline
STILL LEARNING
Member's Gallery
Re: 97 f350 death wobble/hop
Your track bar should be parallel with the drag link. That should get you close to a measurement
__________________
97 CCSB 4WD 7.3 5spd DP Tuner, 6637, 4" Flo-Pro SS Exhaust(3" DP), 99 I/C, T500,Cali Truck w/120cc Split Shot Injectors, 1.0 exhaust housing/WW2, Irate Up-pipes, CCV Mod, Autometer gauges, Valair Organic clutch, PFM 2.25" RSK, PMF Traction bars, Rear Air bags,SD springs Front(V code)/rear(B code), 315/75/16s, 300HP/561TQ
  #3
Old 07-30-2011, 07:38 PM
gnxtc2's Avatar
gnxtc2
Offline
Member's Gallery
You need to get a trac bar under there. Don't ask I how I know
Replace all the worn out components.
And welcome.
Billy T.
gnxtc2@aol.com
__________________
'97 Black F250HD SC 3.55s
Punisher trans, PI Converter,
Dana 60 RSK w/ V & C SD springs
PIS 175/80s, Honey Badger Jr, Comp910s,
Smith Bros Pushrods, ARPs, Fluidampr, IC, E-Fuel
3" Plenums, CJC Traction blocks,
HFHV IDM, T4/BASB, Tuned by
244K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
  #4
Old 07-31-2011, 03:49 AM
weareweird69's Avatar
weareweird69
Offline
Member's Gallery
Also make sure the steering box is in adjustment after you put the track bar on...
__________________
  #5
Old 07-31-2011, 05:19 PM
corybens11
Offline
Member's Gallery
what do you mean about the steering box?
  #6
Old 07-31-2011, 06:12 PM
weareweird69
Offline
Member's Gallery
Theres an adjustment on the box. You can adjust it to tighten the box, but you CAN overtighten it and cause the box to wear out inside.
Theres a jam nut, and a screw on the top of the box opposite the pitman arm. loosen the jam nut, and tighten the screw a 1/4 turn at a time, then tighten the jam nut and try it out.
  #7
Old 07-31-2011, 06:44 PM
corybens11
Offline
Member's Gallery
ok ill have to do that too, i dont know if that would cause it tho? it doesnt seem like its in the steering, more in the suspension, also did these come with sway bars, mine doesnt even have any mounts
  #8
Old 07-31-2011, 07:21 PM
weareweird69
Offline
Member's Gallery
Like I said get the track bar on first. Is there play in your steering wheel? My lightnings death wobble was from the loose steering box. Too much free play in the steering let it wobble badly at random
  #9
Old 08-01-2011, 06:14 AM
old man dave
Offline
Terminator Nation
Member's Gallery
Too much of an adjustment and the steering will not want to return to center. You'll know it when you do it.
__________________
Just another 408hp '97 California Truck with a stock muffler
  #10
Old 08-01-2011, 10:43 PM
corybens11
Offline
Member's Gallery
ok well im gettin a track bar and then ill just take a measurment and get a braket and get new bolts from ford then ill adjust the box and see what it does, mayb rotate the tires? if that doesnt do it mayb ill have to take the fluid out and get them balanced normaly? did 97 have a sway bar by the way?
(View-All Members who have read this thread : 98
1999F350, 4btchev, 84mudder, 95powerstroke, 97f3504x4green, applebutterjones, AZStang, BigWes-7.3, BIG_RED, biostroke1, Blacksmoke7.3, BMFNTOY, bpa658, Bradbilt, Bradysmail1969, bullet, Bushwakd, casper7.3, cgerber, charleslentz, chris horst, clucas6308, corybens11, Countryboy07, cowBOYER, d-selpowereddiebauer, Deezle, Dieselboy740, DNSPSD, dsinderson, Erik_Lee, evans213, EverettWV, f250towrig, farmall16, farmer7.3, firehog2, firestomper, floridastroke, friskyjake, gigabit, gnxtc2, Goldknight, Greger96obs, gsxr1216, HARDTIMES, Hogan1369, hogsnapper7, Huey, ibestrokin97, jeichert, jmegt, Josh2021, jrcoogs, jrracerdad, krafty, littlewoody, lossscause, loudmouth, louisvanwilker, madpogue, Michael97, mojoman, monster., morefuel, NDPSD, nitroteam, ohnasty1, old man dave, OUTLAW-OFFROAD, Petro, PJB, procomp, psdmike, Richie, rockytop, rolsmojave3, Sandpro, slinga, socoman1988, speeddemon31176, spstactical, squeeks, StandAlone, steve burris, sturgeonslayer, t.land, tallpaul, tella, theSLEEPER, toolmangary, TylerHerring, villestrip, vrcarrano, wa96stroke, weareweird69
You may not post new threads
You may not post replies
Forum Jump
