1997 F250 problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 06-10-2011, 07:23 PM
j.soffa's Avatar
j.soffa
Offline
DieselAddict
Member's Gallery
1997 F250 problem
While driving to work a few hours ago my truck just died in the middle of driving. Started right back up while coasting and check engine light came on. 5 seconds later disappeared. Just swang by autozone to get a code, but they said nothing was logged. I've noticed that within the past couple weeks my idle has been degrading. very choppy. Also my voltage meter on my dash started acting funny. It started not moving as far after the glow plugs finish (usually was around the m and a, and will just randomly pick a spot every time I run the truck. Still seems to be charging the batteries... i think. Had it tested at autozone, they said it was fine. Only recent change was a cruise control recall and oil change 5 days ago.
Any input would be helpful. Just at work now. Thanks!
Truck has a 5 month old 250 amp alternator
2month old batteries
New Starter
New Stancor GP relay, all GP's check fine.
Black CPS 2 months ago
trucks got 240,000 on the clock.
__________________
1995 F350 7.3L T444E (not powerstroke) Stage 2 Inj, Terminator HPOP, TS 6-pos.
Old 06-10-2011, 09:45 PM
countryboyrob
Offline
Member's Gallery
Re: 1997 F250 problem
Autozone scanners wont work on our trucks.
__________________
02 f250
  #3
Old 06-10-2011, 10:47 PM
ascrap2003's Avatar
ascrap2003
Offline
Famous words "Watch This"
Member's Gallery
Get a scan first
Also check icp sensor for oil, valve cover gasket connectors for oil/burnt/broken pins.
Could be simple or a combination of problems being your truck is old
I know from experience. Other possibles
include ipr sensor & or connector, faulty cps connector or wires, faulty/chaffed harness wiring.
But hopefully something simple that will show up with a scan
get with a good diesel shop or ford for a scan & have them run
a complete scan along with cct & buzz tests then go from there.
that is where I would start.
__________________
2002 F350 SuperCab SWR Lariat, Hutch Mod, EBPV Delete, Down Pipe,
My websites:
Non Ferrous Metals Recycling
X-ray film recycling
Aircraft Engine Buyers
  #4
Old 06-11-2011, 03:56 AM
Patrick Feeley's Avatar
Patrick Feeley
Offline
Member's Gallery
Also, take a quick look and see if the "tin nut" on the IPR is loose or missing. Cheers!
__________________
(View-All Members who have read this thread : 47
7.3psd97444, ascrap2003, aussie powerstroke, awehrmann, BIG E, Brian Cox, broodu, Bugman, cowboy_dan, cressman_cj, Darkhollow, Desert Rancher, dglenn1969, Dieseltron, DougN, dsinderson, farmer7.3, floridastroke, foxman, FreddieZ, Frenchb85, Goodbar419, Headcase98002, ibestrokin97, j.soffa, JCart, jmsmith76, josh1.123, Josh2021, kramarj, lgjttu, madpogue, Metzman, Patrick Feeley, powerstroke095, rancherstroker6, rashole, salprofish, swff14, TacticalMonk, The Oiler, The Struggler, toolmangary, winkfab, xrcris
You may not post new threads
You may not post replies
Forum Jump
