99 7.3L...no fuel pumping into bowl. - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 06-10-2011, 03:58 PM
Matt07
Offline
Member's Gallery
A friend of mine was on his way to the motion lotion station and truck quit on him. he figured he ran it outta fuel. he put about half a tank in it and kept cranking and cranking it all day yesterday and couldnt get it to start. i went over to check it out and the fuel bowl is not filling up. its got the electric pump on the frame rail. when you turn on the key its runing and sounds normal. but thats the only thing i think it could be is that fuel pump...any other suggestions what it might be?
Reply With Quote Quick reply to this message Go to the top
Old 06-10-2011, 04:09 PM
Harl's Avatar
Harl
Offline
Harl
Member's Gallery
Send a message via AIM to Harl
Re: 99 7.3L...no fuel pumping into bowl.
From what I no, the pump should fill the bowl.. I would check to make sure the pump it self is getting fuel...
__________________
Cody,17
DD-1996 F250 Powerstroke, 5speed, 4x4 ecsb
Mods: GlowShift Gauges-Boost, Pryo, Oil psi and Fuel psi. DIY 6637 Intake, 160/100's, Wildman 6pos, Stage 2 water/meth, D66, TE HPOP, Vailer Clutch, Custom Bars and 5in turbo back....
PT-1995 F350- totaled
Soon to be brought back to a 1992
http://www.youtube.com/truerednecks
  #3
Old 06-10-2011, 04:14 PM
svnmpwr's Avatar
svnmpwr
Offline
Member's Gallery
i just replaced a bad pump that would still turn on, and sounded pretty normal. Pull the line off before the pump and see if its sucking.
__________________
2000 cc/sb lariat 4x4
5in turbo back, 6637, van turbo, swamps sticks, adrenaline hpop, itp RR, wildman tuned, 4in lift, 39'' michelin xml's
  #4
Old 06-10-2011, 04:26 PM
Rustler
Offline
"mad cow" member
Member's Gallery
Open the fuel bowl drain valve, turn key to run, fuel should come out of the valve, close valve cycle key 4 ~ 5 times, then try to start it.
__________________
01 F-250 CC 4R esof PMT AIS, pine tree air freshener,
some other stuff not worth mentioning .
  #5
Old 06-11-2011, 03:45 AM
tbolt's Avatar
tbolt
Offline
Member's Gallery
He said the bowl would not fill. Either a bad pump ar blockage someplace between the pump & tank or something in the tank. But just because you can hear it doesn't mean it's pumping.
__________________
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
  #6
Old 06-11-2011, 12:27 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Sometimes opening the valve and cranking it will get it flowing. If that happens, I would think it meant you have a weak pump though.
I would check flow from the tank before I assumed bad pump though.
__________________
  #7
Old 06-11-2011, 02:10 PM
mckeddie
Offline
Member's Gallery
Motion lotion station? I was going to go get some porn damn it!
I have no flow before or after the pump. I've read there may be no in tank pump on some 99's? The pump seems to be flowing using my highly technical thumb over each end analysis, albeit not too strong. Is there a pump in the tank, or just a mixer for the pickup and return lines? Im going to blow some air through the line back into the tank today tomake sure it isn't blocked, thenreplace the frame pump if that doesn't do anything. Will blowing back through hurt anything? Im guessing since its already full of air, it shouldn't.
  #8
Old 06-11-2011, 02:34 PM
gottagofast's Avatar
gottagofast
Offline
Freak'n know it all
Member's Gallery
these trucks do not have pumps in the tanks... If you are gonna blow into the tank do it through the fuel filler instead... pressurize the tank a little and fuel should come out through the fuel line
__________________
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead, autometer gauges, F-650 dash mod, 4r100 to ZF-6 SWAP, South Bend OFE-K clutch, Gen 2 wicked wheel,
  #9
Old 06-11-2011, 02:42 PM
TylerDurden's Avatar
TylerDurden
Offline
<----Nice headlights!!!
Member's Gallery
If you're going to pull it all apart anyway just replace the lines. Id be looking into my fuel filter housing though to get a better idea of whats in/been in my fuel lines. Id follow ggf's^ advice. Pressurize the tank and the fuel will flow to the pump unless its a blocked line. Did you draw any fuel from the half of a tank you just got? Maybe its got junk in it.
That'd be a great way to burn up a new pump, hooking it up to blocked lines.
Good luck!
__________________
2000 F250 4x4 cc/sb. 6" w/37's and some other stuff.
  #10
Old 06-11-2011, 02:53 PM
mckeddie
Offline
Member's Gallery
Tried pressurizing the tank when everything was hooked. Nothing made it to the fuel bowl. Ill try it again today and see if I get anything out of the line while disconnected. Im still 99% positive I ran it out of fuel, ut had been reading 1/8 tank fir a couple days, which finally connected in my head when the low fuel light kicked on. I was on my way to the station when it died, I just let it coast into the station and up to the pump, I think it sucked some crap from the bottom of the tank up and clogged it, then probably burned the pump up from all the cranking I did the rest of the day.
If you do not want to register, fill this field only and the name will be used as user name for your post.
Human Verification
(View-All Members who have read this thread : 88
01str88, 02bestroked, 03_PSD, 19stroker97, 2001Stroker7.3, 4duggan, 509ford, 6.0 stoke, 738drvr, 96f250psd, aklim, Arisley, Big Chuck, BigBluediesel08, birdog, Black_Clouds, BMF7.3, bryan39175, burtonboarder, Bushwakd, Chad Edwards, Clatterindiesel, cpdad93, Deputydog, DIESEL DAN, DirtyGator, Diverhardhat, dukedrummer89, firstdiesel, Fordpowered, gottagofast, greenmachine07, green_machine, Harl, HillbillyDeluxe99, Jarretthise, Jcavers, Jchappy12, jetdok2r, jfarmer86, jimdawg185, jmsmith76, JoJo, ju015dd, kfluke, knoxville, kpasichnyk, KPSquared, LAredneck6.0, madmaxz, madstone, maineboy11, Matt07, mckeddie, nandomart, ole_blu, podirtfarmer, PowerStroke94, Powerstrokin96, procomp, RedDevil154, Redline7.3L, rollin_smoke, rpm-inc, Rustler, shortbed212, smith7.3, SmokeWithEveryStroke, solefood21, SouthFlstrokin', storker95, stroke99half, Strokin450, svnmpwr, tbolt, tch.280, Timkaylee, Tprov, travis182008, tyler886, TylerDurden, visions1, whitjo, wildbillcody97, Willmister08, withrow, yellowmerc, zilla68
Forum Jump
