7.3 powerstroke blow by - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 06-10-2011, 06:53 AM
bigred94
Offline
Member's Gallery
my truck has 218-219,000 miles and i took it to a shop today they said with all that blow by they assume the motor is gonna die in about 50-100k "if im lucky" i can start it put the oil fill cap and it just sits there doest move or nothing heres a video of it
__________________
94 Powerstroke, 3 inch lift, 3"DP 4" straight pipe to 5" in bed T then to 6" Ausie stacks, DIY intake large Baldwin air filter , Ts 6 position chip custom tunes,3:54 rear end 5 speed trans Rollin on 35" procomp extreme terrains
Old 06-10-2011, 12:26 PM
03_PSD
Offline
Member's Gallery
Re: 7.3 powerstroke blow by
i think your fine
  #3
Old 06-10-2011, 12:39 PM
bluedge8's Avatar
bluedge8
Offline
Member's Gallery
it is very smokey, my truck has 196k on it and I had a van with 253k on it and I had no visible smoke like you have. you don't have excessive blowby though based on the oil cap. I would check out your ccv to make sure its not plugged and double check to make sure you have no coolant in your oil, but your mechanic would have seen that-it makes a milky mess. If all is good there, run it.
__________________
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
  #4
Old 06-10-2011, 01:27 PM
joedaddy's Avatar
joedaddy
Offline
I know nothing...
Member's Gallery
My 330k ccsb has way more than that, it floats the cap like an air hockey puck. It had zero BB when I bought it with the stock air box. As soon as I did cai and DP it started. There's now more density to compress and less bp and that has increased VE.
Spend the next 2-3 years building a long block, that will give you the time and $ to do it right, then swap.
__________________
Doesn't roll with anyone or tag along to be cool...
  #5
Old 06-10-2011, 03:53 PM
tughill283's Avatar
tughill283
Offline
oil burner
Member's Gallery
a steady stream of smoke like that is alright,if it starts puffing smoke out then you know one or two cylinders are toast.
__________________
96 f250, ZF5,160cc,
300k miles
96 f350 plow truck
  #6
Old 06-11-2011, 01:44 AM
bigred94
Offline
Member's Gallery
yea there is no oil or coolant mixed i think maybe the oil vent tube going in to the air intake before the turbo might be clogged but the truck has tons of power towed about 10-11k today and she pulled it like a dream my belief is that he is wrong my 1981 isuzu 2.2 diesel has the same amount of blow by and still has good power and its only got 150,000 miles so i think its fine
  #7
Old 06-11-2011, 01:56 AM
bigred94
Offline
Member's Gallery
i was also gonna ask on a 7.3 powerstroke what do you guys think should be the max egt? i was thinking no more than 1,200 if its gonna be substantiated like towing a trailer up a hill but i was wondering what you guys think
  #8
Old 06-11-2011, 03:31 AM
Nitro41's Avatar
Nitro41
Offline
Member's Gallery
you can run 1250 all day. Anything more then that is rolling the dice. I know plenty of guys on here that say theyve burried 1600* pyros pullin up hills or slammin 2000* out of their 7.3's sled pullin.
for ultimate reliabilty stay under 1300 and you should be good. quick bursts up to 1500-1600 arent horrible if they are for a short period like drag racing
__________________
97 Single Cab F250 4x4 5 speed
Swapped D-60
Locked front and rear
160 sticks
Wildman Tunes
T500 HPOP
OFE clutch
Linex rockers
35" Toyo M/Ts
and a bunch more...
  #9
Old 06-11-2011, 05:45 AM
bigred94
Offline
Member's Gallery
oh haha and i was worried at 1,200 well thats really good to know! thanks nitro!
  #10
Old 06-11-2011, 01:57 PM
JCart
Offline
Member's Gallery
The probe for your pyrometer is installed where? 12-1250 before the turbo is fine. Post turbo e.g., in down pipe can be 400 hotter then pre turbo.
I noted that you have a K&N....(mo) these engines pump too much are for this air filter. Ran one on the 96 and always had trace of dust in the intake check yours and see at next service. Switched to Donaldson paper no dust..... Not slamin K&N still have em on other stuff just not my 7.3...
Cheers
jrc
__________________
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, SRK, SD springs front/rear, 145 litre rear tank (now ZF-5 ).
White / Silver 96 F250 4x2, SCSB E4OD, 4:10 stock for now mods to install: D60, engine stuff.
Truck pix write ups
(View-All Members who have read this thread : 223
03_PSD, 1996_7.3_PSD, 1SLO GT, 4duggan, 7.3 Blackout, 7.3firefighter, 72ford250, 777funk, 89 Stroker, 94strokeher, 95f250psd, 96'BigBlue, 96P_Stroke4x4, 97 F250 PS, 9773, 97powerstrokecclb, 97Stroker13, 99stroker, Adinas95, Alberta 7.3, area51, aussie powerstroke, aussiedave, baddzl, baggedbug, BartZ32tt, Bayonet16, BBottoms, bcvickers, bert, big'un, biggreen96, BigRed02, bigred94, BIG_RED, bluedge8, boost4life, Boydog, Brian Cox, btomassacci, Bugman, Built4tq, Burg460, Bushwakd, carrj66, catfish, cavemanracing, celsiusplumber, cemeyer, cheysays7.3!, Chipnmeg, chromehound, cimarron13, cj45lc, Clatterindiesel, cobrabc1993, Copperhed, crazyc0303, d-selpowereddiebauer, damonjy19, Deererainman, Desert Rancher, Dieselboy740, dieseldave, dieselman, DougN, drwoodchopper, dsinderson, EarlJon97, erainwater, ezygo, F-127, f350plow, farmall16, farmboy93, Fddriver2, fixithud, floridastroke, fordnut, fordtough82, Fordzilla11, friskyjake, fwbkent, Goldknight, Goodbar419, gsxr1216, Harl, Haz-Matt, Haztanker, Headcase98002, heybuddy25, Htownstroker, Hutch, IGoneGreen, iluv83vettes, IraqVetUSMC, itsdieselornothing, jake2far, Jason73, JCart, jetdok2r, JGCF250, JGod, jhedemark, Jinx, jlee, jmsmith76, Jnalaplace, joedaddy, joedown, JoJo, jonesmc711, jonjeep57, Jonni Nitro, Josh2021, JoshBenavides, josh_mangan, jtlane, ju015dd, Jwagoner15, K5383, Kampy, kbos, ken6881, kickstand, kip4234, kramarj, lght1, lightnin, lincolnlocker, loudmouth, madpogue, majorpecs, mattman90, Mike97f350, Millerfarms, Mini-Stroke..., mj1193, mojoman, mtray, NE-STROKE, Nitro41, nitroteam, NRHX2009, OBS F350, OBSpstroke97, ocracokeisland, OLD'SCOOL, ole_blu, Otter70, OUTLAW-OFFROAD, PALMER02, Parts guy, Patrick Feeley, Patrolman, PJB, plzstrokeme, pmasterson, poon, Powerstroke1997, powerstroke9608, PowerstrokeDiesel, powerstrokepride, powerstroker66, procomp, PSDBrian, psu927, pwerstroker, pwr73stroke, PWRstroke_smoke, recordbreaker5, RedNeckRea, Redrock2000, Rmartin-97, Rockyardjo, rodeo_man, rollingthunder, rpm-inc, Rwtrower, salprofish, sand2snow, Sandduner, savvy1, scottsbronc, seandrisc, sg465, Shaun Lindmark, silent64, slabrunner, slinga, smith7.3, Smokin LB7, snoblade82, SouthFlstrokin', SPless, Stang07, stevedrums, Stock 87, strokeorcroak, Suzukirider32, tardymike, tcerohe, The Struggler, the7.3dude, theoldgirl1990, threestud, timfinnegan, Toms014x4, toughbronco, TravisT, tughill283, Tylerjm7.3, tysonxj, V-Ref, V97F350, welderman2008, WidowMaker, winkfab, YohanSegaBowser, zvovchik, zx800x
You may not post new threads
You may not post replies
Forum Jump
