Towing with a 460? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > Gasoline Engine Forum
Thread Tools Display Modes
  #1
Old 06-04-2011, 04:05 PM
Dustball8504's Avatar
Dustball8504
Offline
WOOOOO!!!!!
Member's Gallery
Towing with a 460?
I'm looking at possibly getting a 460 for a second truck. How well can one of these tow with either 3.55 or 4.10 rears? I live in a pretty hilly area also.
__________________
2008 F-250 CCSB Lariat, AFE Stage 2, 4 inch straight pipe, RCD 71mm Batmosphere, DashDAQ, SCT Livewire w/IDP tunes, Traction bars, suspension stops
621RWHP 9-27-12@IDP
Elkton, MD
PSA# 60
Old 06-04-2011, 04:17 PM
vcassens's Avatar
vcassens
Offline
Member's Gallery
Re: Towing with a 460?
It should do fine just hope there is plenty of gas stations
__________________
2006 ford F 250 Amarillo 4" turbo back other than that stock for now
  #3
Old 06-04-2011, 04:28 PM
TylerDurden's Avatar
TylerDurden
Offline
<----Nice headlights!!!
Member's Gallery
When I was running my pool company I had a 96 f250 rc/lb 4x4 auto with 4.10's and it would pull the trailer with the skidloader fine. It was ok at plowing. Trans sucked and at 100k Id been through three of em. In July of 03 I got a 2004 f250 rc/lb xl 4x4 auto with a 5.4 in it as a second/replacement for the 96. I thought I could use it that fall to pull a second trailer with trees on it(we sold spruce/pine trees and planted them). I couldnt put the skiddy, the backhoe attachment, and the trees on the trailer and pull them with the 96. The 5.4 would pull ALL of it though. I kind of abandoned hope in the big block at that point. Sure the 5.4 you had to really get into the pedal to get the load moving but the 460 was the same deal. The 460 just makes more noise which leads you to think you're going for some reason. They are still decent trucks. It'll make you appreciate your diesel a lot more. Oh and the fuel mileage is gonna be in gallons per mile towing. Seriously its almost obscene towing heavy.
__________________
2000 F250 4x4 cc/sb. 6" w/37's and some other stuff.
  #4
Old 06-04-2011, 05:23 PM
Dustball8504
Offline
WOOOOO!!!!!
Member's Gallery
I'm only really looking into a gas option because it'll be a daily driver (less to maintain) and the cost of an equal 7.3 powered truck in my area is considerably higher. The only time it would be towing HEAVY is when it tows the truck in my sig to some truck pulls which would seriously be 5-10 a year and not incredibly far distances.
  #5
Old 06-04-2011, 05:50 PM
TylerDurden
Offline
Member's Gallery
Yeah the cost for a diesel is higher and after towing a 7k lb truck on a trailer with that gasser you'll know why. ha ha..
I do know when the powerstrokes were new people were saying that you could put 40k miles on the gasser before realizing the initial price difference between the two.
  #6
Old 06-04-2011, 05:53 PM
Dustball8504
Offline
WOOOOO!!!!!
Member's Gallery
Oh I know it'll be a chore towing the truck with a gasser, I'm still on the hunt for a cheap 7.3 for this reason but I've seen some very nice 460 trucks go fairly cheap lately.
  #7
Old 06-04-2011, 07:09 PM
TylerDurden
Offline
Member's Gallery
You know, you could get a 2wd diesel pretty cheap and it'd be good for towing on pavement. The 460 will do fine, the worst part will be fueling it. Id say if you can find a nice gasser tow rig, do it. A cc/lb with 4.10's would be sweet! Just for the weight. Ive had a couple and they always start. I just couldnt stand the fuel mileage. Like 7 is normal. Worse than a v10!!
  #8
Old 06-04-2011, 07:15 PM
Dustball8504
Offline
WOOOOO!!!!!
Member's Gallery
Has to be 4wd, the truck in my sig won't be out in the central PA slop of a winter so the second unit has to be 4wd also haha.
  #9
Old 06-04-2011, 07:39 PM
TylerDurden
Offline
Member's Gallery
I agree! I wouldnt own a 2wd truck. The only downer is some of those truck have ttb frontends. Ick! Im sure you could swap it out though.
  #10
Old 06-04-2011, 09:01 PM
Red 93 L1 #3383's Avatar
Red 93 L1 #3383
Offline
Joined cracked block club
Member's Gallery
Find an F-350, they have the solid front axle. I have a '94 F-350 cc/lb 4x4, w/ the 460, E4OD auto, & 4.10's. I average 7-8mpg. It dosen't matter if I have 4000lbs in the box, 8000lbs on the hitch or empty. The longer wheel base is nice for towing.
__________________
e99 F-350 Crew cab 4x4 auto 263k, '01 forged rod motor, bellowed up-pipes, 3.5" down pipe w/ 4" straight pipe, 6637 filter
(View-All Members who have read this thread : 157
!!!PainTrain!!!, 01REDSTROKER, 02 CCSB, 06f3506.0, 16yrenthusiest, 4duggan, 6litergearbeater, 85 f350, 92f350cc, 95f250psd, 96BlkBeauty, 96powerstroker, 97brute, Al Mighty, All Jacked Up, almostfinished, Aminator, ArrizX, aussiedave, awehrmann, badblack01gt, Bci99, BigBlueDually, Binder man, blackbetty13, black_pstroke, BME460, Bmiller5, Bradbilt, Built4tq, Bustedknuckles, CALADASH, caspower, CGMKCM, chappy, Chimera, ckozak10, Clint_FX4_TxBoy, Colorado, Copperhead, Country, cozzb, Critical, Cutting-Edge Diesel, Dave, dbd181, Denver, Desertdweller, Dirt_99, donj1977, donzimama, dragonboi, Dustball8504, Dustin F2504x4, Dusty Roads, dzljon, f250towrig, farmall99, fatkid58, floridastroke, flyboy41, ford fanatic, fordtrucktough, genuineford, greanbeans, greenbeast, gtmustang00, H-Bomb, haulin99sdp, Haztanker, headleyj, Herbigj, Highbeam, ibestrokin97, IGoneGreen, Ithumpwheniwalk, jake1086, Jake2345, jammin60, jawsfx4, Jcam88, JD F350, JDRoaddie, Jjona5, Jonesin, LETHAL WEAPON, lincolnlocker, Mack185, maritimer10, Matt-F350, McFadin(BACON), Mendomotox, milehighstroker, mj250, mjones, monkeys7.3, Msolem, mud on the tires7.3, mxredneck, namerritt, Nelson2011, nova, no_pistons7, OBSBoysel, old man dave, oldschool, oregon96psd, Original Guster, Petro, PJB, Plowboy93, Powerjoke4life, powerstroke095, powerstroke586, ramkiller97, rancher76, Rancherousa, rancherstroker6, Randy_270, Red 93 L1 #3383, rhinopc60, rideracelivemx7, RiverRat, Rmartin-97, RockinJW, Rogers21, rollingthunder, Russo2, RW'sSTROKER, sargepep56, Shaun Lindmark, shookme, smith7.3, Smokin444, Spidey2011, spiff, stackedstroker, ste2, Stem_and_Beans, Stroked550, strokedeis, strokin533, strokingkid1392, studded 6leaker, swff14, towin stroker, tughill283, TylerDurden, vcassens, wannabstrokin, WannaRollCoal, Woody35, Worstenemy453, ZF6Speed250, ZillaRacing989
You may not post new threads
You may not post replies
Forum Jump
