Fuel leak at filter housing - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 05-26-2011, 07:54 PM
6speedSD's Avatar
6speedSD
Offline
David
Member's Gallery
On my dads 03 F350. filter housing on top of the engine, where the fuel line comes in. That little plate that bolts to the side of the housing, it's dripping out the bottom. We checked to make sure the bolts were tight, and they are. Is there an O ring behind there, or is it a gasket?
__________________
2005 F350 CCLB Dually
5" straight piped
Couple deletes, some audio, some video
Some Recon parts
Tuned by Eric... ECM and FICM
Old 05-26-2011, 08:13 PM
lenzhotrod
Offline
Member's Gallery
Re: Fuel leak at filter housing
It is an o-ring. Do yourself a favor and look up 6.0 bible!!!
  #3
Old 05-26-2011, 11:04 PM
6speedSD's Avatar
6speedSD
Offline
David
Member's Gallery
I totally forgot about that. I looked it over a while back. Thanks for the reminder.
  #4
Old 05-27-2011, 03:24 PM
6speedSD's Avatar
6speedSD
Offline
David
Member's Gallery
Anyone know what size it is? I have a couple of o-ring sets at home and want to see if maybe I have it before he makes a trip to the dealership.
  #5
Old 05-27-2011, 09:02 PM
bigdaddy60's Avatar
bigdaddy60
Offline
Dead dinosaur consumer
Member's Gallery
You won't have that one. At work we call it the d!ck gasket because it's shaped..... Well you get the point. Get the whole updated regulator while you're at it. Your injectors will thank you
__________________
2006 F250 ccsb 4wd
ARP studs
Sinister egr delete
OEM gaskets
SCT tuned by Eric at Innovative
35/12.50/20 Dick Cepek FC2
Phantom 2 gauges by Autometer
Silverline duals
A healthy dose of nitrous when needed
  #6
Old 05-27-2011, 10:17 PM
03F250 6.0
Offline
Member's Gallery
if it a 6.o jus do the upgrader fuel pressure spring the sell you the whole kit for around $50 at the dealer this includes new o rings spring and the bolts plus what is bolted to the housing
  #7
Old 05-28-2011, 12:15 AM
amdriven2liv's Avatar
amdriven2liv
Offline
Member's Gallery
Ford Part # 3C3Z-9T517-AE
__________________
Walk to Defeat ALS We Walk for Kay
"I'm hitting easy street on mud tires"
  #8
Old 05-28-2011, 12:20 AM
06-sixoh's Avatar
06-sixoh
Offline
Member's Gallery
I might actually have a spare one... PM if interested.. I will check in a bit
__________________
2006 F250 CCSB FX4 Lariat
GlowShift Tinted gauges, Recon Clear Cab Lights, Diamond Eye Duals, SRL Files, 2.5" rize leveling kit, F350 Rear Blocks, PHP Tuned FICM, Retro Solution 6K HID's, DieselSite Coolant Filter...
2011 Oxford White SuperCrew EcoBoost FX2
  #9
Old 05-28-2011, 12:31 AM
amdriven2liv
Offline
Member's Gallery
Maybe this will help the discussion. My part # is wrong. They changed the kit.
New Fuel pressure regulator kit with blue spring. Worth it or not? - Page 2 - Ford Truck Enthusiasts Forums
  #10
Old 05-28-2011, 03:14 AM
bismic1
Offline
Member's Gallery
TousleyFordParts got this for me:
6E7Z-9C165-B
It was around $38 and it had the blue spring in it along w/ all the o-rings and the poppet. They don't have the part listed, but call them and they will get it. It is the cheapest way to go for the blue spring.
__________________
Mark
06 F250 CC SB FX4 Lariat;ARPs OEM gaskets;Banks exhaust;DynaTrac Balljoints;RACCCV6000;Updated HPOP fitting;JimmiJammers;Ravelco;plugs&standpipes;Fumo to;Harpooned;Quadzilla XZT Fuel Press;Blue spring;DashDAQ;PHP_FICM; RiffRaff boots;DCPower250A w/ Inverter;Rancho7000's;BPD EGR cooler;BPD WaterPump;SCT Matts SRL+;ELC Ultra w/ filter;SynchroMax
(View-All Members who have read this thread : 64
03F250 6.0, 06-sixoh, 06HarleyF250, 06PSD, 07_powerstroke, 393LX, 4diggn, 6speedSD, amdriven2liv, avm112, bigdaddy60, birdog, bismic1, Blake8550, BMWgoneWILD, briggs60, bustednuckles, Chad Edwards, commander2210, Cowboy Cadillac, cpdad93, crabbelle, Dave, Dbook, DevilDocTater, dieselmac, Dlaymance, duff shinn, eatoncobra04, ernieb143, farmboy8630, FL-DIESEL, florida 6.0, FoolishPride, Got4wd, GS247, handyman76310, Ian123, jaypd, JD F350, josh1.123, Liddy, maloneydpm, marchojk, MT Pockets, Mwilsondoors, notch86, orrwhat, pdsw60, ReconDieselPerformance, SaNnDnSurF, SDER1, Shef, Snake, STRAIGHTSTROKEN04, stroker62, stunu13, tekemp, toolmangary, Toybreaker, Vip, william_04_x, zgcain
You may not post new threads
You may not post replies
Forum Jump
