oil gallery plug? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 05-23-2011, 09:35 PM
F250 Fever's Avatar
F250 Fever
Offline
Strokin it in your face!
Member's Gallery
oil gallery plug?
Im almost positive this is where my oil leak is, there is oil coming down the down pipe (i have already changed turbo/pedestal O rings and made sure there is no leak in that area) oand my starter has a film of oil all over it.
My question is there an O ring for the oil gallery plug or do i jus need to buy a new plug? Where can i get one besides the stealership thanks in advance.
__________________
2000 F250 ECSB 137,xxx
Cobalt Pillar Trip pod gauges, trans temp, boost, pyro
Tuned by PHP
4in down pipe to a 5in tip
Tru cool trans cooler
6637
Banks big head waste gate
6in Pro comp lift
Mag hytec tranny pan
Foil delete
ATS Turbo housing
Halo projector headlights
BUILT TRANNIE
Euro taillights
Moog ball joints
Old 05-23-2011, 09:43 PM
R.J.'s Avatar
R.J.
Offline
Member's Gallery
Re: oil gallery plug?
Here is one source for "O" rings
http://dieselorings.com/index.php?pa...by=DESCRIPTION
__________________
Bob
02, F250, 4x4, CC, Auto, Warn manual hubs, Line-X, Isspro Pyro, Boost, Trans temp and Fuel pressure gauges. Wicked Wheel, AIS intake, John Wood valve body, BrakeSmart, DuraFlap Mud Flaps, 6.0/31 row tranny cooler, ITP Regulated Return Kit, Dieselsite coolant filter & 203 thermostat. Cat ELC coolant, MagnaFlow premium exhaust.
  #3
Old 05-23-2011, 10:00 PM
F250 Fever's Avatar
F250 Fever
Offline
Member's Gallery
Originally Posted by R.J. View Post
Sorry noob question but wich one doe i need? Am i calling it the wrong name?
  #4
Old 05-23-2011, 10:54 PM
R.J.'s Avatar
R.J.
Offline
Member's Gallery
This would be the correct "O" ring for the oil galley plugs in the heads.
http://www.dieselorings.com/index.ph...cat=22&group=6
He also has the plug & "O" ring available as a kit.
Although I haven't replaced one yet according to the site the rear plugs must be a PITA to do with the engine in the truck.
  #5
Old 05-23-2011, 11:08 PM
F250 Fever's Avatar
F250 Fever
Offline
Member's Gallery
Yea hopefully someone will give some advice of how i should go about doin this.
  #6
Old 05-24-2011, 02:00 AM
gottagofast's Avatar
gottagofast
Offline
Freak'n know it all
Member's Gallery
no such thing as an oil "gallery".... the oil galley plug on the back of the head is the same as the one on the front.... 1/4" ratchet fits in it.... get your hand back there and feel for it.... Or get a small camera or bore scope and look... it's gonna suck and you may even bleed in the process.... really nothing else to tell really
__________________
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead, autometer gauges, F-650 dash mod, 4r100 to ZF-6 SWAP, South Bend OFE-K clutch, Gen 2 wicked wheel,
  #7
Old 05-24-2011, 02:59 AM
F250 Fever's Avatar
F250 Fever
Offline
Member's Gallery
Thanks for the correction now i dont sound like an idiot lol. This sounds pretty straight forward, so make sure the truck is off and get back there and screw it off and either replace the O ring or the whole plug itself, im sure it will suck doin it but thanks fir your guys help and correct me if im wrong about what i jus said thx.
  #8
Old 05-24-2011, 04:04 AM
gottagofast
Offline
Freak'n know it all
Member's Gallery
thas it.... good luck
  #9
Old 05-24-2011, 04:14 AM
neverkickn's Avatar
neverkickn
Offline
Member's Gallery
Yeah, your gonna want a 1/2in drive ratchet instead. A good long handled one preferably wit a lot of teeth. You have very little room to work in there and if you have too much play in the ratchet then you will have a hard time turning the plugs in/out.
If the plug wont let loose you can use a propane torch to heat it a little.
Loc tite is a must here and you need to have the threads really clean beforehand.
__________________
01 f250 scsb Work Truck
  #10
Old 05-24-2011, 04:18 AM
neverkickn's Avatar
neverkickn
Offline
Member's Gallery
Get a mortar mixing tub from home depot to use as a oil catch. Be careful when you remove the plug as oil will be leaking down at you. I would do this on a cool engine of coarse and remember that after the new plugs are in that it will take a while to fire as the oil rails will be empty. Refer to the instructions on starting up after an injector install.
(View-All Members who have read this thread : 69
01str88, 02 CCSB, 02POWERSTROKE7.3, 16yrenthusiest, 2006nytro, 4duggan, 72ford250, 89 Stroker, 99WHITESTROKE, ackdog, aklim, Alvapowerchoke, Barnbuilder, Bens, biggreen96, birdco85, birdog, bithead08, Bushwakd, cartmanea, chopper, Choupique108, COFG-28, corvairjunky, CTC DEEZUL, dave0642, dmstrucks02, Dusty Roads, dutchymount2, F250 Fever, fyrehose, Gaius, galla35, gottagofast, GWStoke02, HondaTypeRk20, Honeyshucks4, j440, JD3020, jeichert, jess, ju015dd, kilapapipa, kramarj, lght1, milehighstroker, mmarmor, Mudbrother, neverkickn, nujef12, powelce, PowerStrokingMachine, procomp, prodriller, R.J., raptor, rat49f6, rayrayray01, scagle1, shoaboat, slayer7712, sluhbmet, smokinstroker92, sportsdad, Twisted Addiction, xcal9x, yzpsd
You may not post new threads
You may not post replies
Forum Jump
