| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
Truck idles 200psi (hpop) lower with delo vs delvac
Ive been running mobil delvac from walmart in my truck and always had above 500 psi at idle about 600-650psi hpop pressure. i just used delo for the first time because they were out of delvac. did the oil change yesterday and noticed now my oil presure sits at 400psi at idle.. does it mater?
__________________
Rick 2002 F250 CC LB - 5" lift, BTS, 4.10s+trutrac, 250/100s, studs, pushrods, dual springs, ITP RR, 2 SD pumps, Beans plenums, Balanced, Blueprinted and cryod bottom, ported heads, GH 1.5 cam, 4" Exhaust, 6.0 trans cooler OTW- S366/s483 compounds, 20x10 black hostages + 37 13.50 toyos, fresh BTS, Live tuning, And maybe an srp 1.1 |
| Sponsored Links | |
Advertisement |
#2
Re: Truck idles 200psi (hpop) lower with delo vs delvac
I don't see how switching oil brands would make a difference in ICP at idle.
__________________
Curtis 2002 F-250 PSD Gambling with 250/200's on PMR's. 478hp/851tq on Haller's dyno - 7/28/12 Your connection to the Colorado diesel community. |
#3
I do not like Delo...it has very little detergent in it and turns the inside of your engine black. have torn down many Cummins engines that had delo in them, (big rig engines) and thats what we found, black goo on everything. use Shell Rotella T, Union Guardol, or Mobile 1300 super...these all have a good detergent package, and the crap goes out with the oil change...... you can run that delo forra bit, couple thou miles, then get it outta there. just my opinion ....
__________________
'97 Centurion. F350 4x4 CCLB Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh, 6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, 3/8" cooling lines, Tru-Cool Max, PML, Bumper Mod, Gauges, Fluidampr, Mellings LPOP.....Tuned by "The WildMan"..... |
#4
yeah im sticking with delvac. i used to use rotella every change but after i switched to delvac i noticed truck idled smother and quieter, less blowby and was thinker at the end of a 4k mile run. now with delo truck idles rougher again, more blowby and now lower hpop pressure..
#5
for the guys who are going to say go with valvoline extreme blue or shaffers or something synthetic, im running dyno for awhile to get a good break in on the new motor. ill switch to synthetic at 50-75k or something
#6
i have used delo since the fourth oil change in my truck! so for about 75,00 miles now.... had the valve covers off a time or two and looks great.... i've tried rotella, delvac, and motorcraft, and delo runs the smoothest in my truck, i change the oil in my truck every 5k in the summer and 3k in the winter cuz of idle times!!!!! i burn the least amount of oil with the delo too..... had amsoil in there too once but i burned way to much of it to keep running it, about a quart per 1k same with rotella syn..... so i guess its more like 60k with delo
__________________
00,f350 lariat,4x4,cc,drw,38r,bdp stage 2/170cc/100% sticks,bdp live tunes,4''down 5''back,dieselsite boots and adrenaline,diy RR w/walbro,bellowed uppies, BTS trany! |
#7
why so long? why not switch it over after the first oil change?
#8
I'm confused by the claim that DELO doesn't have enough detergent. I've got the OCI reports that show the additive package. Good detergent and great anti-wear additives...Can someone explain?
Best, Jim
__________________
2002 F-350 SC/SB/SRW 4X4 auto- Tymar intake, AIH delete, Swamps injectors, Swamps IDM, Dieselsite Coolant Filter, Bilsteins with a stock ride height.
#9
these engines need to break in atleast 30k with dino is what ive herd from a guys in the powerstroke business
#10
i see. but don't they all come from the stealership with synthetic in it.... or is that just for the new ones.... i thought even back with the 7.3 they came with the semi syn when ford came out with it
(View-All)
Members who have read this thread : 71
| 02POWERSTROKE7.3, 06ford, 2006nytro, 450ciPSD, 505yam, 91turbogsx, bergpsd, BigJake, bigjake0524, bigpete73, birdog, bosssuperduty, Bushwakd, CALADASH, Chad Edwards, chris1978, cj45lc, cp30, dave_k96, deathwishracer, Dieselsvt, Diverhardhat, DRD, Dsycutter, F350-6, flip2spin23, fords4life, Gcashwell, golfer, gottagofast, Harl, Honeyshucks4, isootmypants, JerseyJim, JMart, joediesle, jtlane, ju015dd, Ken Newman, lincolnlocker, locrwln, madmaxz, Mustang06, NE-STROKE, nickeagle, nm351, no-tel-in, Old OutLaw, partsguy84823, PHPDiesel, Pocket, procomp, R.J., ralph, Ranchstroke, Reapster, redrocket, s10extcab2, SLC 7.3, slowduty80, smith7.3, smokinstroker92, stroked2000, strokinak, tbolt, turbodiesel_02, vapstroke, washingtoncoastie, wedge542, whitjo |
| Thread Tools | |
| Display Modes | |
