02 cc has a vibration @ 40 to 55mph? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 05-15-2011, 09:36 PM
biostroke1's Avatar
biostroke1
Offline
biostroke1
Member's Gallery
Hey guys, I was wondering if someone could help me figure out what the heck is causing this vibration that starts around 40mph and fades a little after 50mph? It shakes the tuck enough to cause any image in the rear view mirror to distort. There is no noise like a squeak or grind like a bad u-joint. Ive heard that carrier bearings do go bad. There is some play in the carrier, is there supposed be? My truck has 123k. All suggestions are greatly appreciated. Thanks in advance
Old 05-15-2011, 09:58 PM
tree trimmer's Avatar
tree trimmer
Offline
Member's Gallery
Re: 02 cc has a vibration @ 40 to 55mph?
carrier bearing, out of balance wheel, tierods, ball joints, wheel bearings. because its speed sensitive, ill lean toward a tire
__________________
2010 f350 srw lariat
  #3
Old 05-15-2011, 10:00 PM
florida 6.0's Avatar
florida 6.0
Offline
diesel fiend
Member's Gallery
Is is a long bed ?
__________________
05 F350 9" 4 link , 37's , 4.56 's php and gearhead tuned
  #4
Old 05-15-2011, 10:05 PM
biostroke1's Avatar
biostroke1
Offline
biostroke1
Member's Gallery
About a month ago the truck would shake whenever I start off from a light or stop sign but that went away.
  #5
biostroke1's Avatar
biostroke1
Offline
biostroke1
Member's Gallery
Yes its a long bed
  #6
Old 05-15-2011, 11:13 PM
florida 6.0
Offline
diesel fiend
Member's Gallery
sounds like a carrier bearing
  #7
Old 05-15-2011, 11:23 PM
biostroke1's Avatar
biostroke1
Offline
biostroke1
Member's Gallery
Yea, There is a little slop in mine but I was't sure if that was normal or not.
  #8
Old 05-16-2011, 03:46 AM
Strokerstooge's Avatar
Strokerstooge
Offline
Need a ride.
Member's Gallery
Just had my second carrier bearing go out, a slight vibration and a low howling noise, first was a rubbing sound on tight turns. Their cheap enough to swap out and hopefully its your problem.
__________________
03 F-250 7.3 XLT CC SB Auto 38R, S-B Intake, 4 inch MBRP Duals, Regulated Return, J Wood VB, DP Tuner, Isspros 3 Pillar, Terminator Scan Gauge, DS Coolant Filter, HPX
  #9
Old 05-16-2011, 04:02 AM
biostroke1's Avatar
biostroke1
Offline
biostroke1
Member's Gallery
Should I do the u-joints @ the same time since the drive shaft will be out?
  #10
Old 05-16-2011, 07:27 PM
wooner's Avatar
wooner
Offline
Construction Babysitter
Member's Gallery
do you have a lift?
__________________
Dave
99.5 F250 Lariat : 6" lift on 37" Toyo MT's, DP Tunes, Built Transmission, Airbags, AIH Delete, 38R, Banks Big Head, CCV Mod, Sinister Regulated Return, IH bellowed up pipes, AFE Stage II, ISSPro Performax gauges, Scan Gauge, Casserly Stage I's, T-500 HPOP, Swamp's IDM
(View-All Members who have read this thread : 160
01PSDiesel, 03_PSD, 04fivefour, 04La4iat, 1BadF350, 1badz, 1sd, 2006nytro, 450ciPSD, 5superduty, 907DAVE, 99STROKINSMOKIN, Aaron S, aldayj, almostfinished, asalm36, austin2592, BeaveF250, bfife, bgbeutler, BigDangFord, bigpete73, bill4d, billc, biostroke1, birdog, Blown284, BMF7.3, Bobs 7.3, boostaddict, bosssuperduty, BryceB, Buckeye Wes, cadd, CALADASH, calebgriffin31, camochris, cara_verga, chadder1313, chainsaw, CHevDog1, clackclack, cobrabc1993, codykthekilla, COFG-28, cooldad66216, cwprosser, dbcampbell, dblamp, Dieselpop, Double D's, DoubleTake, duner405, dustinz85, Dusty Roads, Effreem, Firehunter, firemudder, fishinfool98, Fl Stroker, florida 6.0, Fordzilla11, ftb28, geturdun, gmdriscoll, gottagofast, Green037.3, greyf350, GTOKILLER, Hansel, HeadHunter, houtxfdcapt, IL7.3 Powerstroker, jennings94, jonahbass, Jorobe33, Kampy, kfluke, kickstand, klipz, Layson, lbeinks, lincolnlocker, livnlrn, LOOSEWHEEL, Lt.DanHasNewLegs, machete31, madmaxz, Marauder, mayville78, Mekanik, middlemanjw, Mike97f350, mikedb6690, milehighstroker, mjones, morepower02, mrit, mtgrease, mudslinger02, NE-STROKE, NevrKnow, Nitrousjunkie347, no-tel-in, NoahA, NorCalDiesel, Northcountrywood, npen, ole_blu, pappa b's powerstroke, pilot4life, pimp800, PowerstrokeJunkie, PowerstrokeMudder82, powerstroker67, powerstruck7.3, procomp, PwRsTrKe8907, ralph, Rambler, RandysPSD, red&silver04, Roots, RW'sSTROKER, Sapps, schmity, sethc24, shmokenpstroke, shoaboat, SickStroke6.0, silent64, smokindiesel2, smokinstroker92, southmike, sparksmx450, squints, sstec, SteveBricks, stevedrums, sticky, Strokerstooge, Strokin 02, super73, tbar18, tbolt, terrye, tholt34, TOTO WARN, TPeqJR, tree trimmer, UP2NOGD88, Use to be a Dodge guy, wiltface, Wizzard of Odds, wooner, yobuda, zilla68
You may not post new threads
You may not post replies
Forum Jump
