| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
6.0 blowing out white smoke
my dad has a 6.0 and this morning going to work it was pouring out white smoke from the exhaust so bad it looked like there was fog outside. finally settled down a bit but kept doing it all day. head gaskets?? or possibly a stuck injector or something?
whats do you guys think?? i own a 7.3 and im not familar with his 6.0
__________________
97 7.3 PHP Phoenix IDM mod AFE Big Boost 06 SD rear springs Bilstein 5100s 3" MBRP downpipe 4 inch lift Glowshift gauges- trans temp, boost, egt |
| Sponsored Links | |
Advertisement |
#2
Re: 6.0 blowing out white smoke
Probably a blown egr cooler. Egr delete time
#3
get that egr cooler off there before it takes the headgaskets with it. Don't forget the oil cooler too.
__________________
06 ccsb got alil done.... |
#4
What does the smoke smell like?
Are you losing coolant leve in your degas bottle?
__________________
Mark 06 F250 CC SB FX4 Lariat;ARPs OEM gaskets;Banks exhaust;DynaTrac Balljoints;RACCCV6000;Updated HPOP fitting;JimmiJammers;Ravelco;plugs&standpipes;Fumo to;Harpooned;Quadzilla XZT Fuel Press;Blue spring;DashDAQ;PHP_FICM; RiffRaff boots;DCPower250A w/ Inverter;Rancho7000's;BPD EGR cooler;BPD WaterPump;SCT Matts SRL+;ELC Ultra w/ filter;SynchroMax |
#5
__________________
![]() 04 6.0l Excursion 4x4 6" Lift, 35' BFG's, Powermax AFE Intake, CFM+ Swamps 58v ficm, ARP, EGR delete Sct x3 w/ID,DJ,GH tunes, Autometer/Isspro 4"MBRP SS exhaust cat/muffler delete 6.4 banjos, FPR spring upgrade Shell Ultra ELC, Coolant filter, CCV mod, Zoodad Mod 07' Harley headlights, 08' Tow mirros Hellwig swaybar, Billstein 5100's |
#6
A failed injector can look the same way. Hopefully the OP has figured out his issue - whatever it is .....
#7
Make sure its smoke... a blown egr will blow steam out of the exhaust and it will look like white smoke. If he's losing coolant that's probably the culprit.
#8
Egr cooler or injector..smell the exhaust and injector will smell strongly of fuel
__________________
2008 Ford F250 6.4 PSD. Spartan 350, 5inch Flo-pro, downpipe, AFE stage 2, Intercooler pipe, ZEX nitrous, TS-MP8, Elite wastegate/EGR delete, ARP studs, CFM plenum, pro comp trac bars, Airdog 150, ATS 5-star, Mag-Hytec pans, Readylift, 35's, Road Armor front, Fab four rear bumper. |
#9
egr cooler thanks guys. gettin that deleted!
| Thread Tools | |
| Display Modes | |
