Oil change and upgrade - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 7.3L Power Stroke - Aftermarket & Performance
Thread Tools Display Modes
  #1
Old 08-22-2007, 04:34 PM
thetonka's Avatar
thetonka
Offline
Member's Gallery
My truck now has 237K on it, but I do not drive it as much since I commute on a motorcycle now. Its primary duty is as a tow rig and bad weather commuter(not too common in sunny SoCal ). I have been running Rotella in it since I got it and have done numerous blackstone reports all with great result. I have been running 5000 mile change intervals for 4 years now.
I always wanted to put in a bypass filter and syn oils, but never really had to time or money. I am planning on doing some PM on the truck in a few weeks and was thinking about this topic again. Now the thing is that even though the yearly mileage is less, its TOUGH work. My hauler is 15K lbs with a lot of wind resistance, and most trips down here are in hot weather. So what advantages would I be seeing if I went with a bypass and syn oil? What are the pros and cons of the different bypasses? What are the pros and cons of the different oils(Amsoil, Shaeffer, redline, etc.)? I can figure the cost aspect so I am more interested in what this would add to the truck as far as protection and performance. I am going to be replacing the stock injectors soon with singles, plus putting in a 6L CAC and bigger exhaust. I want to do what I can to make this engine last to 400K.
Thanks
__________________
2001 F350 CC LB 4X4
TN, AIS, DP 80hp, ITP boost elim, Magnaflow 4".
Tows the big white hauler.
When life gives you Lemons, throw them at the stupid people.
Old 08-22-2007, 04:37 PM
gregrob's Avatar
gregrob
Offline
Member's Gallery
Re: Oil change and upgrade
a bypass filter will keep the oil clean but it won't keep it from shearing down. That's the bigger problem in a PSD.
I'm not sure a bypass will extend drain intervals long enough to make it worth while.
thehammer69 would be a good person to ask. He's running an oilguard bypass unit and expirements with different oils.
  #3
Old 08-22-2007, 04:48 PM
thetonka's Avatar
thetonka
Offline
Member's Gallery
Thats been my concern. I have read a few references to the shearing but not enough info. If the syns can help with this I will start running a good syn, even at the cost since it will be a longer time between oil changes. I also worry about what sitting will do to the oils and engine. I have heard in the past the marketing claims of better coverage during starting. If the truck sits for 2 weeks or more between driving it is there any advantage to putting in a syn oil, or maybe an additive?
Thanks
  #4
Old 08-22-2007, 07:23 PM
Haul_n_horses2's Avatar
Haul_n_horses2
Offline
Member's Gallery
I used to run Mobil Delvac 1 and Mobil 1 filters with Oilguard bypass. I have been able to extend my drain interval/filter change to 15K miles with no reduction in viscosity and with plenty of additive still left. Shearing is a BIG problem with the 6 leaker and is not a problem with 7.3 generally. However, with dual HPOP, I have heard reports that shearing becomes more of an issue. For that reason (and others) I switched oil to Schaeffer's 9000 5W40. Schaeffer's 9000 is the only oil I am aware of that did not shear significantly in the 6.0L PSD. We will see how it holds up with my dual HPOP 7.3L PSD.
  #5
Old 08-22-2007, 07:37 PM
thetonka's Avatar
thetonka
Offline
Member's Gallery
Interesting, what about the 6L makes it shear more than the 7.3L?
Either way if Shaeffers is better than I'll look into it. I am hoping to find something I like and buy in bulk. Hopefully can find something that has oils that I can run in the Jeep, Truck and my motorcyle(of course not the same exact oil but something in the companies line) so I can try and get a builk discount with mix and match products from the same company. I used to trust the local shell shop for oil changes but the lied to my wife the last time she was in there so, no more. I just gotta find somewhere that will take used oil, in like 5-10 gallon quantities for recycling. Maybe even larger.
Is it just me or is the number of companies and people you can trust getting smaller and smaller?
  #6
Old 08-22-2007, 07:42 PM
gregrob's Avatar
gregrob
Offline
Member's Gallery
Hammer has told me that his Schaffer's 5-40 shears down to a 30wt in less than 3000 miles
  #7
Old 08-22-2007, 07:59 PM
Haul_n_horses2
Offline
Member's Gallery
That's news to me. He is the biggest Schaeffers cheerleader around, .
  #8
Old 08-22-2007, 08:02 PM
Deerezilla's Avatar
Deerezilla
Offline
Non Helpful Member
Member's Gallery
I have been running 15w40 7000 series schaeffers all of my truck life and all my equipment run it I have don't oil samples on bolth of my 7.3 with big oil and both do not shear. it's great oil some of my equipment run at 2500rpm for 24hror more and allways right over the gov and some have over 12khr on them never been open up
__________________
2 fords that make no power
  #9
Old 08-22-2007, 08:13 PM
thetonka's Avatar
thetonka
Offline
Member's Gallery
How pricey is Shaeffers, and where do I get it?
  #10
Old 08-22-2007, 08:53 PM
Haul_n_horses2
Offline
Member's Gallery
You can get Schaeffers from their network. Purchase $400 at once in case quantities and the shipping is free, IIRC. Ryan Bean carries it or check out the dealer network http://www.schaefferoil.com/dealer_locator.html Schaeffer's 9000 is about $21 a gallon. Mobil Delvac 1 is $32 a gallon by comparison. Rotella synthetic has excellent performance in stock 7.3 PSD and is cheapest of all.
(View-All Members who have read this thread : 68
00PSD1, 02Bluestroker, Al Mighty, badford350, bigbluthunder, Bigred, Big_Mack, BMac, boggerr, bpa658, brokexj, Bushwakd, Caballo Diablo, cantrellc123, cemeyer, chadder1313, chris1978, Cmonster, CooterBrown, cota, CSIPSD, dag, daytondiesel, Deerezilla, Deputydog, ditch_dawg, Fast_Ashley, greenbeast, Haul_n_horses2, htcafe, humdinger, imelmo, jelk151, jinco, joediesle, Johnny77Mutt, jtharvey, LarryM, Long0, Luke909, MrBill1, NCT, old man dave, plainredtruck, racehauler, radio flyer, rich in co, RockinJW, Rustler, skylinedan, Slated4Greatness, smorris, southmike, TerminatorEngineering, THEDIESELMAN, thehammer69, thetonka, Tom S, Tx Stroker, UNCOOL, VC-Racing, w4racing, zx800x
You may not post new threads
You may not post replies
Forum Jump
