P1247 code what does it mean???? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 05-04-2011, 10:02 PM
Diesel_Kidd222
Offline
Member's Gallery
I have a 2001 7.3 with a edge evo cts and the diagnostic reader said that I have a P1247 code and idk what it means I could use some help.
Old 05-04-2011, 10:30 PM
PSDEng's Avatar
PSDEng
Offline
Busted Knuckles
Member's Gallery
Re: P1247 code what does it mean????
That is a MAP code. Check for leaks, I think that code is a low boost code. Do you have a tuner/chip?
__________________
'97 Powerstroke SCLB: http://www.carsonstaufferdiesel.com
http://www.beansdieselperformance.com
i have a couple friends that went balls deep in wyotech and when they got out they couldn't poor piss out of a boot if you put the directions on the sole
  #3
Old 05-04-2011, 10:35 PM
CSIPSD
Offline
Banned
Member's Gallery
Turbo boost pressure low...
Check for leaks, check for connection at the MAP sensor, check the up pipes...
Do you have gauges?
  #4
Old 05-08-2011, 06:43 PM
Diesel_Kidd222
Offline
Member's Gallery
Noo I don't have gauges but I have a programmer an edge evo cts and today it popped up more codes a p0733 in stage 2 and I wouldn't go into reverse so I switched it back to stock and it went into reverse then. Then on the way home in stock setting it wouldn't change into secong gear it popped up a p0732.
  #5
Old 05-08-2011, 08:49 PM
CSIPSD
Offline
Banned
Member's Gallery
Man, did you sink your truck in a lake???
Check the tranny harness at both the Fire wall and at the tranny. Sounds like a loose or corroded wire...
(View-All Members who have read this thread : 78
2dedge, 450ciPSD, 4wydnr, 95powersmoker, Acton, ADubDiesel, ascrap2003, Automan, bigern515, Boostaddict08, Boydog, Centxdiesel, Chado, cleatus, COFG-28, CSIPSD, darkside708, dentexpowerstroke, destructoxvi@yahoo.com, Diesel_Kidd222, ditch_dawg, dmstrucks02, Driles85, duncan351, Effreem, excursion7.3, f250-01, Fast&Strong, ftb28, ghamrick, Gibrid4x4, jff987, johnrhodes, jth4570, kickstand, kypowerstroke, lght1, LittleRedStroker, lowbedriver, Luke909, manzos, markt, mertz, metalphd, middlemanjw, mlewis_486, monkeys7.3, mustang8992, Ouch, procomp, PSDEng, R.J., rconcrete, rcooper919, Rockyardjo, roughneck0913, screagle07, SD01WD, shockuman, simpleman, slayer7712, snoel123, spgtti72, stlhdfishr, Stroken7.3, TARM, Tflook59, The Oiler, TL3, Tom S, Toms014x4, toolmangary, vintage way, Wap Rican, washingtoncoastie, whitjo, wss440
You may not post new threads
You may not post replies
Forum Jump
