Ficm problem? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 04-30-2011, 05:08 PM
wfodiesel's Avatar
wfodiesel
Offline
Member's Gallery
Ficm problem?
My 6.0 is running rough at idle. Ficm voltage is dropping from 48v to 42v then back up again. I swapped a good ficm to see if that was the problem but no change. Battery voltage is good and no loose wires that I can see. Is the PCM a problem or wiring harness? Any ideas would help.
__________________
The road goes on forever and the party never ends!!
Old 04-30-2011, 06:47 PM
irontx25
Offline
I Just Break Stuff
Member's Gallery
Re: Ficm problem?
I would be looking into not only loose , frayed wiring. Also my entire charging system. Starting with my grounds. That's kinda odd that a second ficm would do the same thing. Did you check ficm#2 while it was on the original truck? It's not uncommon for people to swapp a bad ficm for a bad ficm.
__________________
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Powermax
Warren Diesel 205/100s
Fluidampr
Coolant bypass filter
AFE stg2 intake
Built at Tranny
GoGo Direct Solenoid
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
  #3
Old 04-30-2011, 07:43 PM
Komelika's Avatar
Komelika
Offline
Member's Gallery
Re: Ficm problem?
I just had a mechanic run a diagnostic on my 06' this morning. My FICM was showing ~50V and would drop a few volts, but not much. He said if the FICM was bad it would be dropping to ~30V. I would suspect a bad injector. When he had my truck plugged in he disabled one injector to show me what a bad injector would do and the truck ran really rough.
Also, if you swap your FICM don't you have to reflash all the modules to get them to recognize each other? I didn't think they were all plug and play.
__________________
2006 Ford F250 Lariat 6.0L Powerstoke
  #4
Old 05-01-2011, 01:29 AM
bismic1
Offline
Member's Gallery
Re: Ficm problem?
FICM should NOT be below 46V. Also, they can be bad even when they show the proper voltage.
__________________
Mark
06 F250 CC SB FX4 Lariat;ARPs OEM gaskets;Banks exhaust;DynaTrac Balljoints;RACCCV6000;Updated HPOP fitting;JimmiJammers;Ravelco;plugs&standpipes;Fumo to;Harpooned;Quadzilla XZT Fuel Press;Blue spring;DashDAQ;PHP_FICM; RiffRaff boots;DCPower250A w/ Inverter;Rancho7000's;BPD EGR cooler;BPD WaterPump;SCT Matts SRL+;ELC Ultra w/ filter;SynchroMax
  #5
Old 05-01-2011, 07:07 PM
Kilroy's Avatar
Kilroy
Offline
Kilroy was here
Member's Gallery
Re: Ficm problem?
Speaking of voltage, what should the output voltage from the alternator be?
__________________
2006 6.0L Harley Davidson Edition
ARP studs & Black Onyx Gaskets
Turbo-back Magna Flow 4"
DieselSite Bypass Coolant & Oil Filter
Sinister EGR Delete
  #6
Old 05-01-2011, 07:44 PM
amdriven2liv's Avatar
amdriven2liv
Offline
Member's Gallery
Re: Ficm problem?
Below I have added to the list of Xgauges Fords specs for the FICM Xgauges.
KO=KEY ON LI=LOW IDLE HI=HIGH IDLE OR=OPERATING RANGE
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced.
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
__________________
Walk to Defeat ALS We Walk for Kay
"I'm hitting easy street on mud tires"
  #7
Old 05-02-2011, 03:52 AM
wfodiesel's Avatar
wfodiesel
Offline
Member's Gallery
Re: Ficm problem?
Thanks for the posts, I didn't think voltage was supposed to be below 47 but wasnt positive.
  #8
Old 05-02-2011, 03:00 PM
Mdub707's Avatar
Mdub707
Offline
Damnkids Motorsports
Member's Gallery
Send a message via AIM to Mdub707
Re: Ficm problem?
No, you can use any year FICM on any truck. If you buy a brand new FICM from Ford, it needs to be flashed though, since it's "empty" new.
__________________
DamnKids Motorsports
2006 F-250 6.0 4x4 Vegistroked
SCT Xcal2 w/Innovative Diesel Tuning 466/772 7/19/08
Black smoke don't mean it's broke... it means your tuning sucks!
Originally Posted by CSIPSD View Post
Paypal can go fuk themselfs... Buy me a beer the next time we meet.
  #9
Old 05-02-2011, 08:37 PM
ftb28
Offline
Member's Gallery
Re: Ficm problem?
Do you have to have it "flashed" in the truck or can it be off the truck? Cause if it has to be in the truck I have a major task ahead of me just getting my truck to ford. Another question would be can you just get the FICM rebuilt, or would it be smarter to just buy a new one?
  #10
Old 05-02-2011, 09:59 PM
2004Stroker6.0's Avatar
2004Stroker6.0
Offline
Decorated Deer Killer
Member's Gallery
Re: Ficm problem?
Check swamps diesel they are great people and took care of me got me my FICM overnighted and it was a 58V.
__________________
2004 F250, CCSB, 6.0L,
4" Turbo Back,
5" Y-Pipe Bed Kit,
6.25" Black Chrome Mitre Stacks,
Exhaust By Twisted Diesel,
SCT Custom Tunes by Eric@Innovative,
58V FICM by Swamps,
Airaid Intake + Zoodad Mod,
4" Lift and 2" Shackle,
Black Moto Metal 951's,
35/12.5/18 Toyo M/T's,
Pioneer Indash Touchscreen and MTX sub.
(View-All Members who have read this thread : 117
04250, 2004Stroker6.0, 2006.1f250, 2ndHandSmoke, 6.0Pwrstroke, 6litrestroker, 83notcho, 86F250, 97F250 HD, acplowboy84, amdriven2liv, asatriano, bboteler, BDS, BigBlack03, bigc12v, bigdaddy60, bismic1, Blow-n-Smoke, Broken 6.O, buc1096, bustednuckles, caere, caissiel, CoryC, cowboyengel, Dangyo, Darkhorse, darren.corbin@gmail.com, DBM, dexleo2, Diesel Jay, Dieselboy740, dieselmac, disnet, dunatic, East County stroker, elevateloren, f-150_xl, F-25000, f350bart, F350R, florida 6.0, flynbryn, Ford3544, Fordfreak4life, freeride808, FTAJ, ftb28, Gibrid4x4, GuhrSnowRemoval, Hillz, hill_billiez, iceman89m, id: 5520, irontx25, isimar, jackedup6.0, jamhok, JD F350, JESTERxHEAD, JJLEMAY, Jordy53, Kap1783, kaso76, KEVO, Kilroy, kirbybear, Komelika, Kountryboy 6.0, krackhouse, ktmrydr686, lancer, LBZ_Duramax, Loonatic, Low Key, lubeowner, matty169, Mdub707, Michael97, mike10dunn, moose7.3IH, MT Pockets, Nelly87, nelsonar, nickPSD, Ol'Red95, panheadmark, panther777, papas83, patrickke, rdr99, rerunss, RickF350, RocknRoll, SaNnDnSurF, silverf250, Skintback, sled hauler, smokin250, Smut, srwdoug, stackedstroker, strkn, stroked99_1/2, Super Duty Dude, svilla, Theveazel13, toolmangary, wfodiesel, WichitaF250, worldwide73, yeehaw, ZF6Speed250, Zmann, zx800x
You may not post new threads
You may not post replies
Forum Jump
