Where to find the factory keyless entry code on 08 F350?? - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.4L Power Stroke - Technical Info
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #11
Old 05-03-2011, 04:24 AM
TXTech11
Offline
Member's Gallery
Re: Where to find the factory keyless entry code on 08 F350??
Originally Posted by Dirty Curry Racing View Post
Yikes, that's a little distributing if it was that easy.
ya, but I highly doubt someone would get your vin #, call a ford dealer, get the pin, and then go back to your truck to get in... when a brick would get it done a lot quicker.
hopefully. lol.
__________________
2008 F250 Lariat
Suspension: Rancho 4"
Wheels/Tires: Diamo 17k / Toyo 35x12.5R20
Mini Maxx (Hot Damn)
Flo-Pro 4" DOC/DPF Delete
S&B CAI
Reply With Quote Quick reply to this message Go to the top
Old 05-04-2011, 02:56 AM
scott2001's Avatar
scott2001
Offline
Member's Gallery
thats what insurance is for.
__________________
2008 got a new flex pipe installed. S-b intake, 4in dp back exhaust, gear head tunes
1999 chevy malibu with 183,000 miles on the clock
2013 dodge charger
  #13
Old 05-04-2011, 05:06 PM
Dirty Curry Racing's Avatar
Dirty Curry Racing
Offline
C10H20
Member's Gallery
hopefully. lol.
Very true with the brick, But to play a practical joke on some buddies I know would be worth it
__________________
Rig: 2010 F250 CC SB 4x4
Tuner: H&S Mini Maxx HD300
Tuner setting: Hot
Trans Tuning: 1 shift Schedule low modifier
Curb Weight w/Driver: 8360lbs
Best 1/4 time: 13.55 @99mph with HD300 tune
  #14
Old 05-05-2011, 05:19 PM
Pyro2nite
Offline
Member's Gallery
I know this question has been asked in other forms. If I remember most think it is somewhere around the fuse panel or maybe under it. To change the code to a personal one, you will need the original code.
__________________
2008 FX4 SC SB 6 Speed Mini Maxx Kem tunes
  #15
Old 05-06-2011, 12:09 PM
charlie.harley
Offline
Member's Gallery
Smile Re: Where to find the factory keyless entry code on 08 F350??
I had read it was printed on the ECM?
  #16
Old 05-06-2011, 12:49 PM
mortal798
Offline
Banned
Member's Gallery
Here it is from the Ford service manual:
"Vehicles equipped with a keyless entry keypad are programmed with a factory set 5-digit entry code. This code is provided to the customer on a wallet card in the Owner Literature package. In addition, this code is available through the use of a scan tool, and is printed on the SJB label located on the back side of the module (installed position). When entering codes, each digit must be entered within 5 seconds of the previous button press."
The SJB is the fuse/relay panel in the passenger side kick panel. You will need to unbolt it and flip it over - there should be a sticker on it with your code.
  #17
Old 05-06-2011, 12:52 PM
mortal798
Offline
Banned
Member's Gallery
Here are the programming instructions:
"Programming a Personal Entry Code and Keypad Association to Memory Features (If Equipped)
NOTE: The system allows 3 personal codes to be programmed.
NOTE: Multiple personal codes can be programmed in one step. When programming multiple codes in one step, each code must be programmed by entering each button within 5 seconds of each other. If 5 seconds elapse between any button press, programming mode is exited.
NOTE: If only a single personal code is desired or unable to program multiple codes in one step, each personal code can be programmed individually by repeating Steps 1-5 for each code desired.
Enter the factory set 5-digit keyless entry keypad code.
Within 5 seconds, press the 1/2 button on the keypad to activate the programming mode.
Enter the new personal 5-digit keyless entry keypad code. Each number must be entered within 5 seconds of each other.
After entering the new personal code, press a 6th button to program each new code.
Pressing 1/2 stores the first personal code (if equipped with memory, this code is associated with driver 1 settings).
Pressing 3/4 stores the second personal code (if equipped with memory, this code is associated with driver 2 settings).
Pressing 5/6, 7/8 or 9/0 stores the third personal code, but does not associate the code with a memory setting.
The door locks lock and unlock to confirm the new code is programmed.
Erasing a Personal Entry Code
Within 5 seconds, press the 1/2 button on the keypad and release.
Within 5 seconds, press and hold the 1/2 button for 2 seconds.
All personal codes are now erased and only the factory set 5-digit code works."
  #18
Old 05-07-2011, 02:25 AM
mortal798
Offline
Banned
Member's Gallery
Did you find it yet?
  #19
Old 05-12-2011, 11:11 PM
Muzbomb's Avatar
Muzbomb
Offline
GOT WOOD!!!!
Member's Gallery
Hey guys i kept calling and bugging them so much that they did it for free for me They hooked the computer up and good to go. Thanks again guys
__________________
2009 F350 Lariat, 67's ceramic coated DP, Flo-Pro 5" downpipe back with6"tip, S&B Intake, Spartan, EGR delete, Icon 2.5" leveling kit with BDS trac bar, 1"TEI spacer, 5" rear blocks, Pro Comp tration bars, 20x10 Evulve chrome rims w35"Mickey Thompson MTZ, 20x8.5American Eagle rims w305/55R20 Studded Dura Trac, HID lights, Rigid 20"LED combo
  #20
Old 07-08-2012, 11:57 PM
freddie's Avatar
freddie
Offline
Powerstroked
Member's Gallery
That is the correct location for the code, in case any of you are wondering. It is in small print. Took 5 minutes to remove kick panel, un bolt the module, and turn it enough to find the code.
__________________
97 F250 CCSB
If you do not want to register, fill this field only and the name will be used as user name for your post.
Human Verification
(View-All Members who have read this thread : 224
04 stroker, 06powerstroke, 07outlawpowerstroke, 08azsuperdutyf350, 08murderedout, 08powerstroke22, 1Quik46, 2002FordPwr, 6.4international, 6.4Strokin, 6litrestroker, 87jumpy, 94.5 Stroker, 99-350, ajordan193, alldaysports, ARCTICCAT, BAR-6.4, baskin6.4, BBottoms, bcorum, BeastPowerX10, beemc, BIG STROKER, big*diesel, bigdaddy60, Bigdave, Bigfordguy07, BigRedBlackSmoke, billv999, bjane1, Bldghosp, Blk350on20s, bosssuperduty, bridgesb51, budtoh3zo, Canada0937, Cass, cbenn, charlie.harley, chodifer, cjames, claybuster, co04cobra, Cobra23, Comp7.3, compromised, coolvette, CutThroat, dag4566, daveslawn, dbs0026, Deal80013, Deere8420, deereman, DevjWilliams, diesel dane, diesel71, DieselDZ, DieselG, dieselman64, Dieslnevan2009, Dirty Curry Racing, dlange, dnuts1980, DOHC, dorton413, drh4250, Dtm030, dweber2, eastern, El king-350, eleventhtruck, Evil Diesel, FarmBoyStroker, ffnremt143, fireresource, Firestroke21, FoolishPride, forcefed6.4ford, fordman4286, fordpowerf450, FordSuperDuty05, freddie, freeride808, giddyup, GMAN1, gman77, gracing, graffittticoupe, greaseltn, GreenMachine, Greenshield, hawkeye, hirollin87, HLS, hook13, Iowa PWRSTKE, island8, jakbd, jake1086, jdgleason, jdsf350, jeepnfool, Jhowell, jim1828, Jm5687, joefalco, joestroo, john, johnnyroastbeef, Jughead361, jurquhart, justin202, KCMEADOWS, keblmo, keets HD, Kerrsy, LILGSX, Lmgrpowerstroke, Luda25, Luther's 2008, Mack185, Mac_330, MahdeyS, MAVEXTREME, Maxwedge2, mclean, me2, Meaty JTizzle, Mike-n-md, Mike97f350, MississippiJoe, mnwake, mortal798, MrMike06, Mtl_Hbt_S, Muzbomb, mydually, NevrKnow, NickNasty18, nikkony, Nixon, novakid69, nutsnboltsjp, O86.4stroker, okiebindernut, oldbluef250, Oliver, one2nine, ookla, p8ntballn2, Pan4905, Pcoz88, pitbull37, pog, Poh, PokinDaPower, pooter, poppinjohnny, powersmokin64, Powerstroke Racer, powerstroken03, powr2stroke, Pyro2nite, raybass, rbwyatt, RC4WD, reis1995, ricg, Rick59, Rollincoal97, rollininmy64, ronnyz, Rook, roughneck0913, Roz, rrch129, salamonmilliken, SAYIWONT, scott2001, shanev10, shootingstar, silent64, sixmassive, SKIRK, skobiak, Smokenblack08, smokin250, smokyred, Snake, snopro_69, Stout, stroked1, Stroker, strokin20, Strokin4life, superdutyfarmer, sy1616, tbsimmons, tensixniner, tnsmoke, TODDXDC, tougas, tree trimmer, tsedsell, Twotone08, txrlk, TXTech11, Tyson, uga33, Uncle Buck, USMC6.0, vanislejimmy, Varney, White_monster, Willis, Wizzard of Odds, xcessivebronco, ZaneD, zilla68, Zray
Forum Jump
