My 97 CCSB build - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 General Aftermarket
Thread Tools Display Modes
  #1
Old 04-27-2011, 01:54 AM
diesel_brad's Avatar
diesel_brad
Offline
STILL LEARNING
Member's Gallery
My 97 CCSB build
Well i figured i might as well start a build thread. I di not plan on getting to involved with this truck but I cant help myself.
It is a 97 CCSB 7.3 5spd 147k on the truck. I am the 4th owner.
When i first got it, it needed rear spring hangers and shackles. I did those, got them from NAPA. While I had the bed off doing those i noticed the rear shock hangers are pretty bad, so i picked up a good used pair, i still need to put them on.
Spring hangers and shackles - PowerStrokeNation
I then had an issue with the e-brake not holding. So i tore into the rear brakes. I had a n axle seal leaking and worn down shoes. So it got new shoes, hardware and a axle seal. i also upgraded the rear diff cover to the 08 aluminum cover.
Rear axle seal - PowerStrokeNation
Cast Aluminum SD Rear Differential Cover on OBS - PowerStrokeNation
Next up was to get the truck inspected. Well while getting inspected, it needed front brakes, axle u-joints and ball joints. So i said F the Dana 50 and picked up a 95 Dana 60. So far, the complete axle was tore down, sandblasted painted, new ball joints(XRF), axle u-joints(spicer), spindle bearings and seals, axle seals, pinion seal, made a new passenger side u-bolt plate, steering linkage(XRF), and Spicer's extra thick diff cover.
Dana 60 passenger U-bolt plate - PowerStrokeNation
Got another Dana 60 - PowerStrokeNation
Next up is to get a SRW pair of front hubs, new rotors,and calipers and Install the D60 w my SKY RSK, SD "V" code springs and Bilstine 5100 seires shocks from Cary T(OBSWIZ).
After i get that in the front, I will have to see what exactly I want to do with the rear of the truck.
Today i thru a set of 285s on the truck, that i got off of one of my parts trucks.
I will try to keep this thread updated as things get done.
After the suspension is figured out, a clutch and exhaust will be done, then some body work.
__________________
I am probably the most hated person on here, and I don't care
97 CCSB 4WD DRW 7.3 5spd DP Tuner, 6637, Flo-Pro SS Exhaust, 99 I/C, T500, Autometer gauges, Valair Organic clutch, PFM 2.25" RSK, SD springs Front/rear 315/75/16s,
Bunch of other trucks
Old 04-27-2011, 01:57 AM
Super_Hauler's Avatar
Super_Hauler
Offline
Super Hauler!
Member's Gallery
Re: My 97 CCSB build
didnt you just buy this truck not to long ago? Seems these are the exact pictures you showed us when you bought it.
__________________
MINE:08 F-250 CCSB king ranch erics tunes livewire
99: sclb 6 speed, 4" lift,4" exhaust, EB
99 F-450: ccfb Boss v plow. 6 speed 5" ex,EB
HERS:2001 F-350 ccsb notta stock!
[/quote]
I change my HPOP reservoir oil
  #3
Old 04-27-2011, 01:58 AM
diesel_brad
Offline
STILL LEARNING
Member's Gallery
Yes. I bought it presidents day. the top pic is the day i bought it at the dealer.
And i could'nt find the thread that I thought I started when i bought it
  #4
Old 04-27-2011, 02:04 AM
swamp_ratt's Avatar
swamp_ratt
Offline
Member's Gallery
looks nice with the 285s and no hubcaps. good luck and have fun
__________________
1995 F350 CCLB SRW 4x4 "Animal"
DT360
Allison 1000
AAM 1150 Rear
6oh Intercooler
6oh Fan/7.3 Clutch
Hx52/ht4 (76/85mm) Compounds, Contagious 480cc P7100 and 5x20s, Custom Manton Pushrods, PBM 190# Valve Springs, Ported Head, Custom Pump Mounting Plate and Gear, Custom Intake, Header, and Valve Cover Coming Soon
  #5
Old 04-27-2011, 02:22 AM
madpogue
Offline
Member's Gallery
No caps on the Alcoas, esp. with the open steel lug nuts, just looks like they fell off. At least get some push-thru caps and capped nuts. But IMHO, the traditional caps look best.
Please assure us you're gonna preserve the silver-red-silver two-tone. Anyone who paints a monochrome over a two-tone should have their PSD taken away, be made to watch an entire season of "Dancing With the Stars", and be issued a CumminGs. With an automatic.
  #6
Old 04-27-2011, 02:51 AM
dbd181's Avatar
dbd181
Offline
FordDave
Member's Gallery
I'm watching this one.
__________________
99.5 F-250 ECSB 4x4 auto.
Intake with Donaldson B085011, muffler delete, stock exhaust straight piped.
  #7
Old 04-27-2011, 09:25 AM
diesel_brad
Offline
STILL LEARNING
Member's Gallery
These alcoas are going too. I just threw these on till I get my 315s on my centerlines with the RSK and SD springs
As for the 2 tone. Well the toreador red is going!. It is going to be silver and white instead
  #8
Old 04-27-2011, 01:14 PM
TNScrambler's Avatar
TNScrambler
Offline
Member's Gallery
Send a message via AIM to TNScrambler
Looking good Brad....seems these ccsb trucks have a way of pulling people in....I was looking for a SD when I bought mine, and just happened on a good deal.....now its turned into a full on project truck and currently getting parts gathered up for a zf-6 swap.
Glad to hear your keeping the two tone, I've more than once thought about going two tone on my truck when I get around to painting it.
Justin
__________________
'96 F250 Crew Cab Short Bus 4x4, Lariat '07 SD Seats, D60, SD springs, Hard Knox low lift RSK, E40D, IDM mod, 3in downpipe with 4in exhaust, wix 6637 air filter, hydroboost brakes, 38 gallon rear fuel tank, 4.10 LS with 285s on stock alum.
www.knoxauto.com
www.efienginesupply.com
  #9
Old 04-27-2011, 02:09 PM
BigStroker's Avatar
BigStroker
Offline
The Original
Member's Gallery
Brad,
Lemme know when your ready for that clutch and exhaust
__________________
[CENTER]1994 F350 4x4 5spd, 1995 F250 4x4 5spd, 1996 F250 4x2 auto, 1997 F350 4x4 auto, 1997 F250 4x2 auto
#27
  #10
Old 04-27-2011, 02:18 PM
wildstang
Offline
Member's Gallery
Very nice truck. I have a 96 ccsb 7.3 auto. In rough shape but only paid $4000 for it in 2008. Take some measurements of how much lift you gain with the rsk compared to stock.
(View-All Members who have read this thread : 1065
'94IDITurbo7.3, 01Stroker4x4, 02ccpsd, 02singlewheel, 03-blue-Powerstroke, 03f3507.3, 03fathead6.0, 03International, 03sub4wstr, 04smokeman, 04yfzkid, 06stroker250, 07_powerstroke, 086.4xcab, 08murderedout, 101kkl99, 1978psd, 1990 Scorpion, 1992ccsbpsd, 1995eddie, 1995stroker, 1996Powerstroke7.3, 1997F350powerstroke, 1997stroker!, 1999 7.3L, 19stroker97, 1badpsd, 1faststroke, 1meanpowerstroke, 1SLO GT, 1tonrcr, 1TonStroker, 2000Censtroker, 2000strokeinwhite, 2006Duty, 220Swift, 23stroker1997, 300,000 and counting, 4.0l sahara, 444CuiOBS, 4btchev, 4doorshortbox, 4duggan, 4rcFed, 4wydnr, 5 oh, 505yam, 5150Mikey, 521TURBO, 6.0TJ, 6.4pstroker, 6.9performance, 6.9PoweredScout, 7.3 Chick, 7.3EvilDieZel, 7.3L F-250, 7.3lsmoker, 7.3LStrokeR, 7.3maniac, 7.3psd97444, 7.3_Stroker, 77broncodriver, 79broncoidi, 79Ford7.3, 808diesel, 83f350, 84mudder, 87 F250 6.9L, 907DAVE, 91forddiesel, 92f350cc, 94.5 Stroker, 94.5PSD, 94idi, 94Matt, 94powerstroke, 94youngturbo, 95cclbd, 95doodoo, 95f250stroker, 95gasser, 95powersmoker, 95PwrSmoke, 95tutone444, 96 stroker, 96BlkBeauty, 96Crewcab7.3, 96extccabsb, 96F350Kid, 96f350psd, 96ford250, 96gas2diesel, 96powersmoker, 96powerstroke96, 96powerstroker, 96PSD, 96psdkris, 96pstroke, 96strok, 96stroker5spd, 96strokerbp, 96strokerbz, 96txstroker, 97 F250 PS, 97 f350 p-stroke, 97 flatbed f-350, 97 smoker, 97-7.3powerstroke, 97Beast, 97blackbetty, 97CCLB410LS, 97ccsb, 97crewcab, 97f3504x4green, 97f350blackedoutstroker, 97flatbedkid, 97Heavy Duty, 97obs, 97Powerstroke Boy, 97psd16.5mpg, 97PSDiesel, 97Red350, 97RuffRyd, 97slow, 97strokeonit, 97Stroker13, 97stroker5, 97supercab, 97white, 97_powerstroker, 97_pstroker, 97_Stroker, 99 SD PSD, 997.3PSD, 99f-250, 99F250Smitty, 99powerstrokedually, a5t1, aaronhall, AccordinToJordan, ACFarmer, acleadingham, Ada, adcausey, AddictedOffroad, addison, Adinas95, Admorgan90, adrenalinejunky81, AF_Dwayn, Agjake11, agomez, ajfetterman, AK Diesel, Al Mighty, Alberta 7.3, AlligatorBryan, Allis190, alpinhi, Alvapowerchoke, Aminator, ampgage, andrewv_24, andrewz, ANIMOSITY, ARawls, arcticcat307, ArcticCat843, Arcturus, ArmyGuy45, ashman148, atedder91, Ausm7499, Aweasel, AZStang, b.clair54, Babyguuuurrlll, babyjones, Backcountry284, backroad7.3l, BadDogPSD, baggedbug, BambiBasher, Bamboo, barney1, Bayonet16, BayRoan, BB&D, BBottoms, bddmax, bert, bfilippini26, bfoster, bftank, Big Schwag, bigblock_ford1969, BIGCOUNTRY418, BIGDOGTRUCKER, BigEasy, biggreen96, BigJeremy, BIGN, bignastyGS, bigrob54, bigwhite96stroker, BigWhite97, Binder man, BIODOSE, biostroke1, birddog55, Biscayne, bknight187, Blackbullet73, blackf250, BlackFrd, blacksmoke powerstroke, black_pstroke, BlindViper, BlkNTan, blown smoke, bluedevilslax, bluedge8, bluesbish, BMFNTOY, bmwmark2, bnbdiesel83, BockDiesel, bodaciouscj7, Bombsquad450r, Bones96, bonetown, bonser16, Boomer22, Boostin10s, borncountry, bossmankx, bourneenterprises, bpa658, br9050, bracketracer, brads96 stroker, Brain's 97 Diesel, BRAVO, brfootball45, briece83, brock04gt, brokebronco, Brosten, brower3, btaylor08, btomassacci, Bubbawagsf250, bucklee00, buckles25, Bulldog, Burton7.3, camd94234, camochris, cams-76, CamTom12, CanadianPS, Carver94F350, Caster, CATnappin, cavemanracing, ccf350stroker, cclb865, cdhc10, CDP, cfdeng7, cfsmith1987, cgerber, Chadahootchie, chadrico63, chainfeed, Chimera, Choupique108, Chris's Dually, Chris0121, Chris6.0, Chubaka, Churchz, Cincinnati Guy, cjsobas, ckhuggins, Class of 97, Clouse2411, Cloverleaffarm, CMPNS8N, cntryboy17, co04cobra, codykthekilla, colbev57, Colorado, cooter, Copesetic, Copperhead, Copperhed, corn fed, Cory_S, Coueshunter, Countryboy07, cozzb, Crash1, crashrescue, crewcabxlt, cruisertom, csp, ctdiesel99, cumminskiller69, Cundiff, CURTIS250, D2HP, D66stroke, dalejrfan88, damonty94, Danner96FordF250, dannymack, dark20011, Darkhollow, dave186, Dave7.3, davey99ps, david tx, dbd181, deadinthewater, deercreekstroker, Deere, Deererainman, deezeljunky, dego_red, Denver, devinferg, dheadge, diesel dane, diesel78, dieselboy01, DieselDavid, Dieseldude97, DieselFreak92, DieselGirl11, diesellaxer, dieselman9773, Dieseltron, diesel_brad, Dieslnevan2009, dirtbiker109d, dirtboy25, Dirtyboy82, Dirt_99, DIYiT, DIYMechanic, djhankspowerstroke, DMDP, dmoser27, DNichols3288, DNSPSD, docko1257, double-s-diesel, dragonboi, Drew2010, driveline, DRT1359, drwoodchopper, dtownford5, dukedrummer89, dupee426, Dustball8504, duxpsd, dwbierbach, dwelder454, DZLAL, dzljon, dzlstroker, E55 Bulldog, e99pstroke73, earlybroncoboy, Eight, Elgin MGP, ellisfl09, Epd444, epic82, eric96ford, eric96obs, Erik_Lee, Erle385, erskine_e, estrada5.9, Etaylor, evans213, EverettWV, ezygo, F-127, f250towrig, f350plow, fabricationfool, Falls250, farmboy93, FarmBoyStroker, farmer09, farmer7.3, farmwelder86, fatsix, firehog2, firemanp, firewalker, fitzih29, fixithud, FL-R, FlatbedCowboy, Flatbedcowboy1, FlatbedRocketship, Fleatickchad, Flippincgfighter, floridastroke, Ford Pride, Ford005, ford0220, ford2go, fordboy, fordfan7, FordFever, Fordfreak4life, fordfreak84, fordnut, FordX4-offroad, Fordzilla11, ford_trck, Fourplay II, Fox24, foxman, fpOwerstRokeD, FreighTrain, Frenchb85, fullmetaledges, fummins97, Fyrman25, g.w buffalo, Gaius, GallopingFord, GASMAN6674, gbkeith, geared_low550, geargrabbin97, GENIUSLOERTS, Gertrude, ghohouston, GM Duraturd, Gmalino, gnxtc2, Goober1979, Goose1995, goosyboy, Got4wd, gould9, greenbeast, Greger96obs, Grizz, gsxr1216, gtndrty, guitarjesus, H-Bomb, halbig7, hami3533, Harl, harley1iron, haulin99sdp, haymaker02, hcwt, Headcase98002, hehman250, hellerb68, Herbigj, hfoote, Hijo202, Himark800, HMWH, HoboStroker, Hog_Slayer, hokie93, HossPSD, hottspyder@yahoo.com, Hprpartytruck, Htownstroker, hunter scar, Hunter'97, hwstem, ianjadkins, ibestrokin97, Idaho Shooter, idtex, iluv83vettes, ingrahams, intense134, Issacdilldine, itsallinthestroke, itsdieselornothing, j440, jake9458, Jakey, James W, Jamie V, jankestang12, jasiri, Jason.Horath, Jaydiesel7.3, jbrixen, jbt8080, JCart, jclem, JD3020, JDnAZ, jdrescher, jdubb823, jebowling, jeephildo, jeichert, jeremiahmercier, JetskiMark, jgbike, JGench, JGod, JI97PSD, jim dandy, jimmiejet, jimmyducati, Jinx, JJKpowerstroke, jjreagan, jkmola, jmbasile2, JMCX, Jnalaplace, Jngreen, Joe, Joe's06, joedaddy, Joedambroten, joedown, John Martens, johndeereman, Johnny12, johnnyquest, Jonah52, jonboy84, jonesobs73, Jonni Nitro, Josh2021, josh77, josh_mangan, jr6.4stroker, jrcoogs, JRF, jrlax5, JRod, jrracerdad, jschildm, Jstrong43, jtgf250, jtlane, juniort444e, junk, Justin-D-7.3, Justincredible, JustinR, jvc1990, K5383, kaker123, kanuck15, kawamatt2, kb2red, kbos, KCDAXFACTOR, KCMEADOWS, kirkbarb427, klos, kmanxj, knkanji, kramarj, Kramerstroker, Krause, KrawlerHauler, kystroker7.3, LarryR, LawnRanger, leojr, lex, LGibbs91, LiftedREDStroker, lil o rinny, littlewoody, long_n_white, lossscause, loudmouth, louieman2008, lovesdunes, lowboy18011, LTbrassballs, ltracer06, lwhaples, Lysons, M8xpld, macbanner, MacDinho, MadMaxwell87, madpogue, mandkole, maritimer10, marqese, martinique78, mason93, mattman90, Matt_P, Maverick26, maverik2711, MB97PSD, MDRhoads360587, MeanGreen, merlinnilrem, metrojd, MFD T-3, mghay, MHJ, Michael5126, michealamxamc, Michigan37, MidTNStroke, MidwestOBS, Mike1996F350, Mike97f350, MikeDually, milehighstroker, Millerfarms, MJBSEVENTHREE, Mjk, mjonesjr, mjpage69, MNpower, mnwake, mondosteve, monster-energy-825, Monumentally, moore20017.3, moose7.3IH, MortonJoe96, MOTO7.3, MR.KITTEN, Mr.Wonderful, mr4speedford, mrford, mud on the tires7.3, Mudder_Trucker, muddy951, Mudstomper99, MustangMatt96GT, mwalsh9152, mxredneck, My95stroker, Myles_S, nards_13, Nascar, nawojtko, ncovey, NE-STROKE, Neal 97 250, necks00, nickeagle, nielsencod, NMB2, NmbrStroker, Nodge, noslofivoh, nossliw, not enoughsmoke, nova, no_pistons7, np205, NRHX2009, nrook, NRose, NutFarmer97, NWPAStroker, Oakes, OBS F350, OBSdan, OBSWIZ, Oc96stroker, OilBurner62, old man dave, Old OutLaw, OLD'SCOOL, oldfordisbetter, oldschool, OldschoolPSD, Oldsmoky96, Ole, Ole Nasty, ole red, olepowerstroke, ol_blue97, one time, oneton, ono_55, oregon96psd, Original Guster, Otter70, outcast01, OUTLAW-OFFROAD, OUTLAW101, Outlaw507, pappa b's powerstroke, paretf350, Parky50, Patrick Feeley, pbuxton11, pc97f350, pdizzleinmt, pdj4814, pennsylvaniabo, Petro, pff250hd, Pinski1015, Pipeliner08, PJB, Plumkrzy, plzstrokeme, pmasterson, Pobonner, Poh, polish pete, pontiacross, poon, poorboy's stroker, portlandareae28, power73, Power97Stroke, Powerjoke4life, PowerPerformanceChainsaw, powersmoker73, powerstroke cowboy, Powerstroke newb, powerstroke095, powerstroke33096, PowerstrokeDiesel, powerstrokefarmboy, powerstrokemike, PowerstrokeOBS, PowerstrokeSS, Powerstroke_Kid, powerstrokin7.3, powerstrokin97, Powerstrokinfirefighter, prstrk025, PSD&IDI, psd444, PSDEng, PSDfan99, psdmike, PsRumors, PSscrapper88, pstroke666, Psyched, pullinstroker97, purple_heart_350, pwrstrk4x4, quadindad, quartershot, radcustoms, Rancherousa, rancherstroker6, randylamarr, Randysrollincoal, Ranger50, ranger5150, Rantheman, ranthom, Raul@stealth-automotive, raybass, rayd1969, Rayjay25, Rbernardi, rd2boys!, ready81, red&silver04, red450IH, Redline7.3, redlined88, Redman84, redneckabbott, redpower, Renegade7.3, Rhinotoyz, Richardi503, rideracelivemx7, ridgetd, RidinHigh, rieckebuiltfab, Ringostar, rkesar, Rmartin-97, rnelsen, Robjesup88, rockets10510, RockinJW, ROCKSTAR815, rollerink, rollinhot, Roxanne_97, rpm-inc, Russ, Russo2, Rusty-Ford, rusty1161, rylerwick102, sailor95, salprofish, Sapps, sargepep56, sasquatch, Satan's chariot, saville, SAYiWONT8, scarlet_nape, Schneider 86, screamnstroker, sdm, sdm250, Seven Three, seven.3psd, sg465, sharpmotors, Shaun Lindmark, shawner9ster, shiftracing17, Shiryas, shmokenpstroke, ShogunRider, Shovel, shvlhead78, Sidewinder4.9l, silent64, Silver GT, silverf250, SinisterDiesel, SirStrokeAlot, Six Liter, sjdiesel, skeetreecetw, Skitzer91, slammed83mazda, Slanty12, slayer7712, Sledge, Sleeper., sling, slinga, Slog58, slowngreen, slutz4, sly10, Smash Fascism, smcox1, smgappa, smith7.3, Smoker00, Smokin LB7, smokin250, Smokin444, smokin99stroke, smokin_fast, Smoothcriminal, snaponprofile, Sndwrkr, snoblade82, snowdragon, socoman1988, Sodbuster Jr., sonofahunter, SootRoller, SouthFlstrokin', SouthJerseyStroker, southtexasidi, spadone, sparkey75, Sparky350, spectreblazer, speeddemon31176, speedman, spencer922, SPless, spokanepaul, spongebob915, Spray7.3, spstactical, srfd1195, StandAlone, star73, ste2, steelhorse08, steve burris, STK97PSD, Stokes, stoneykegonsa, Stroke00, stroke7.3this, stroke931, Stroked02, stroked99_1/2, strokeorcroak, StroKer01, stroker1999, Stroker96, Strokeradict, strokerfan, Strokersace, strokertown, StrokerTurbo7.3, strokethis02, Strokin 1, Strokin 35s, strokin 7.3, strokin n smokinn, strokin'_tatsch, strokin1027, Strokin450, strokin97psd, strokindd, strokinfarmtruck, stroking94, strokingkid1392, struttnruttn, Stunt hard, stupid_rope, sully5882, superbee1, superdutyman97, SuperRod, superstroke80, Super_Hauler, suprhlr, swaan, swade-o, swamp_ratt, swff14, t.land, t444epsd, TacticalMonk, Taylor22, tbutera2112, tecatehubbs, Tedb, teevo20, ten speed, Teninoguy, texascamber, the great white, The Red Monster, thebluetruck, TheColt, TheDirt, TheFinalStroke, theoldgirl1990, THETANK01, thorin, Thrilbilly97, Tiff, Tim Gott, timberchad, Tinman23, tjl, TNR, TNScrambler, toads250, Toddpz71, Tom H, Tom S, tonka350, tonto13, toolmangary, tougas, towsurfer, tredav39, tripletdairies, Truck4, turboaz2, turbolab, twentyfootdaredevil, TxAG'97, TXStroker97, Ty's Diesel, tyler731, tyler886, u.f.o., UGA's 96 F350 Crew Cab4X4, USMCTJ13, Utah7.3, V97F350, VA2010Stroker, voodoomaker, vrcarrano, Wackerjr, WAD357, wadeclinton, Wadevan, wanabebig, wannabstrokin, Wardy70, washingtoncoastie, wastroke, weareweird69, webb06, wesjordan, whiskeymike, white06lbz, whitestroker97, WhtMule, Why Not, whytry, WichitaF250, wildstang, Wilson444, winkfab, wint, Wojo, Wolfe88Ford, WolfTraxx, woodking, wrenchturner250, wsm, wvmike, wynndaddy, xcessivebronco, XR7, xrcris, yankstrap, ymeofcr, yogr, YoungFordAddict66, younggun55, Youngwvcoalroller, ytee, yz85rider2002, YZGUYONE25, zabeard, zcampbell90, Zelaznr, zhudgens, zilla68, ZillaRacing989, zipp, zkurtz, zluikens, Zrock, _ubeenstroked_
You may not post new threads
You may not post replies
Forum Jump
