rear axle gear oil weight - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 04-23-2011, 07:33 PM
lifestroker97's Avatar
lifestroker97
Offline
SJD
Member's Gallery
I'm puttin a new diff. cover on my 97 f350.
i'm reading/hearing a mix between 75W-140 and 80W-90
idk which one it is.
anyone know?
__________________
97 sclb 5 speed.
baby swamps & e-fuel
custom TS 6 position tunes
6637 intake
3" dp to dual 6" stacks.
a list of other add-ons
Old 04-23-2011, 07:50 PM
Bradbilt's Avatar
Bradbilt
Offline
STILL LEARNING
Member's Gallery
Re: rear axle gear oil weight
anyone know?
IIRC my tag on the axle stated 75-140w and synthetic
__________________
97 CCSB 4WD 7.3 5spd DP Tuner, 6637, 4" Flo-Pro SS Exhaust(3" DP), 99 I/C, T500,Cali Truck w/120cc Split Shot Injectors, 1.0 exhaust housing/WW2, Irate Up-pipes, CCV Mod, Autometer gauges, Valair Organic clutch, PFM 2.25" RSK, PMF Traction bars, Rear Air bags,SD springs Front(V code)/rear(B code), 315/75/16s, 300HP/561TQ
  #3
Old 04-23-2011, 07:51 PM
Marc's Avatar
Marc
Offline
Member's Gallery
75-140 synthetic in the rear (dont forget a bottle of friction modifier if you have a limited slip)
80-90 dino is the factory oil in the front
__________________
NHRDA Region 2 Race Director
Email
  #4
Old 04-23-2011, 07:54 PM
DEMON's Avatar
DEMON
Offline
Member's Gallery
yup. 80-90 not good enough for the rear.
__________________
Luke
'06 Ford F450 CC DRW Lariate 24" Alcoas & Toyos
'98 Freightliner FLB C12 13spd 244"
'73 Chevy RS/Z-28
Originally Posted by swamp_ratt View Post
yeah its similar to that one but unfortunately not nearly as long or as cool
  #5
Old 04-23-2011, 08:06 PM
TylerDurden's Avatar
TylerDurden
Offline
<----Nice headlights!!!
Member's Gallery
Bingo...get two or three cans of brake cleaner too...get all the bs metal outta the pumpkin.
There is a tag captive to the diff cover bolts that says 75w-140 Synthetic
I know that the front calls for different stuff buuuuut I use the same in both ends...I use RP and even though their stuff isnt considered good anymore I use it because I tried one of the 'good' ones and it sucked. Made it about four months and I couldnt take the noise, clunking and performance anymore. Went back to rp and all those issues disappeared...
Fwiw, mobil 1 makes a good syn gear oil in this weight. Cheaper than RP.
__________________
2000 F250 4x4 cc/sb. 6" w/37's and some other stuff.
  #6
Old 04-23-2011, 08:27 PM
lifestroker97
Offline
SJD
Member's Gallery
thanks guys.
i think i'm gonna run AMSOIL in the rear end.
i just fixed a fuel leak earlier this morning and was checkin all the lines when i found a pin hole in the diff cover so for now it's just the rear but i'll take care of the front diff before this winter.
any other comments on brand of oil? just to get a feel for what other guys are runnin.
  #7
Old 04-23-2011, 08:36 PM
lifestroker97
Offline
SJD
Member's Gallery
how many quarts does it hold?
i'm not gettin a big name brand aftermarket cover,
it'll be close to stock.
but around 3 or 4 qts?
  #8
Old 04-24-2011, 02:12 AM
pstroke96's Avatar
pstroke96
Offline
Offical Puddle Displacer
Member's Gallery
Send a message via AIM to pstroke96
a stock 08 cover makes for a nice upgrade over the stocker. its realitively inexpensive, about 60 bucks i think. you will need new hardware though its thicker
__________________
Refugee
  #9
Old 04-24-2011, 03:05 AM
Bradbilt's Avatar
Bradbilt
Offline
STILL LEARNING
Member's Gallery
7.5 pints including friction modifier if you have a limited slip
Diff cover....>>>>>Cast Aluminum SD Rear Differential Cover on OBS - PowerStrokeNation
  #10
Old 04-24-2011, 04:28 AM
JCart
Offline
Member's Gallery
http://www.redlineoil.com/product.aspx?pid=44&pcid=8
I used the above with 08 diff cover....
jrc
__________________
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, SRK, SD springs front/rear, 145 litre rear tank (now ZF-5 ).
White / Silver 96 F250 4x2, SCSB E4OD, 4:10 stock for now mods to install: D60, engine stuff.
Truck pix write ups
(View-All Members who have read this thread : 160
02 CCSB, 1990 Scorpion, 1996timemachine, 6.0power, 7.3maniac, 91turbogsx, 97PowerHusk, AZStang, Bamboo, Bayonet16, bentpushrod, bfoster, bfreezy, bftank, Big Head, biggreen96, Bigtimearcher, billmoody1, birdog, bmxanrchy127, Bradbilt, BRAVO, Buddy B, canzer106, ccorbin, Centxdiesel, chromehound, cimarron13, Clarkestrong, Clouse2411, cnyqui09, Cody48, constF350, Cummingsrobert, Cutty72, dauntejoel, dave186, DEMON, Desert Rancher, Diesel Avenger, dieselman, Diverhardhat, donthelegend, drh4250, dsinderson, enenuenue, Erik_Lee, EverettWV, farsci, freddie, FX4 F2-Fifty, Gaius, gamblerhydra, geared_low550, Grandmaspeedshop, Gunterf, H-Bomb, halo, hawaiiandiesel, hendricksbus, HILL631, HoboStroker, Hodadd, Honda30, hskrpwr, Jason.Horath, JCart, Jcbemer, jefhuf, jeremiahmercier, jff987, jlr9897, Jnalaplace, John-Boy, john.s.hammond, JRF, JRs_Outlaw, Kampy, kevinw, King Valley, kmanxj, Kuntry, kystanger, leoneo01, lifestroker97, lincolnlocker, lowboy18011, LTbrassballs, madpogue, Map22, Marc, markyt, mcdaniel1991, meltdown122, Mendomotox, mikev96814, moorea, morefuel, mxjeepin, mxredneck, natebub, ngtstk3r, Nick spends, nickeagle, No Regrets, ol' blue 7.3, otis_301, PAbowhunter, Patrick Feeley, pdj4814, PLast, powerstroke095, PSDEng, psdmike, PsRumors, pstroke96, Pure Evil, raptor, redpower, Robs94z, roddy, Roenicke95stroker, rooster, rusty1161, s-moe, savvy1, scout man, screagle07, Sea97Stroker, sgoochds650, Shaun Lindmark, Shaunc5, shawnberrier, sitnlopro99gt, slickwillie, slowmans, smallblockfox, sparksf250, SRSeiders, StandAlone, stevv, sticks55, stroodles, Swamp239, The Fabricator, Thomas7.3psd, ToddM715, towsurfer, truckin87, TylerDurden, wes3623, Wheels, xrcris, xwaaamanx, zarrinvz24, zilla68
You may not post new threads
You may not post replies
Forum Jump
