97 powerstroke low boost and power - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 04-21-2011, 05:46 AM
97-BIG RED's Avatar
97-BIG RED
Offline
00stroke97
Member's Gallery
i have a 97 f250 powerstroke that i have had a major loss of power and boost and poor fuel mileage. it started when my buddy tried putting his edge cts on my truck brfore setting his back to stock. it froze his edge up and had t0 have it reset. my truck had always had a bit of sputter to it pulling in third gear but would still get up and go. i have had my pcm reflashed but didnt help. i do have oil in the icp sensor. the truck starts up fine and runs fine but if i get on it boost doesnt build till about 2 and half grand 3rd gear (5 speed) its real sluggish. ive checked the uvc harness by unpluggin each conector one by one and each time the truck ran different. i unpluged the icp and the truck ran no different. it does run better with the map unplugged but i have switched it out and didnt help. now im lost can it be the icp or another sensor maybe ipr any help thanks guys
Old 04-21-2011, 01:24 PM
Cratos's Avatar
Cratos
Offline
Member's Gallery
Re: 97 powerstroke low boost and power
could be boot or plenum leak mix up some sopy warte ans spray it around the boots and plenum you may have a loose or leaking boot or the plenums may have to be resealed with the gray goo. how is you fuel pressure and have you changed you filter latley? fule and air = boost so one or the other is laking.
__________________
Blue 2012 XLT SCLB 4X4 , 15,000 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter kit, ccv mod, deleted :)
  #3
Old 04-21-2011, 03:00 PM
95powersmoker's Avatar
95powersmoker
Offline
Member's Gallery
Check your uppipes for soot on them or the firewall...
__________________
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
  #4
Old 04-21-2011, 03:29 PM
7.3psd97444's Avatar
7.3psd97444
Offline
OBS Addict
Member's Gallery
^ what they said.
__________________
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
  #5
Old 04-21-2011, 04:34 PM
ltjag101
Offline
Member's Gallery
i have a similar issue except the turbo one day got real loud so i try to keep the revs down so i dont go into surge untill i can look into the leak or whatever is causing the turbo to rev too much
  #6
Old 04-21-2011, 05:08 PM
7.3psd97444
Offline
OBS Addict
Member's Gallery
uh a leak wont cause over speeding the turbo. you will loose boost(turbo speed).....
  #7
Old 04-22-2011, 12:50 AM
97-BIG RED's Avatar
97-BIG RED
Offline
00stroke97
Member's Gallery
have a new fuel filter only about three months old ill go try checking the the boots with soapy water. i havent checked the fuel pressure yet
  #8
Old 04-22-2011, 12:53 AM
7.3psd97444
Offline
OBS Addict
Member's Gallery
Up pipe leaks are common. Check then too.
  #9
Old 04-22-2011, 03:58 AM
97-BIG RED's Avatar
97-BIG RED
Offline
00stroke97
Member's Gallery
i checked foe leaks with the soapy water none. i checked my fuel presurre gauge bounces between 50 and 60 psi at idle
  #10
Old 04-22-2011, 12:54 PM
7.3psd97444
Offline
OBS Addict
Member's Gallery
Ok. Fuel pressure seems good. Did you check your UP-PIPES?
(View-All Members who have read this thread : 265
01grnstroker, 03-blue-Powerstroke, 1990 Scorpion, 19Dually97, 1badpsd, 1craneguy, 1SLO GT, 4duggan, 4x4 Nut, 7.3psd1999, 7.3psd97444, 72ford250, 887.3DirtyD, 91blackshortbus, 94 psd, 94.5stroker, 94strokeher, 95powersmoker, 96'BigBlue, 96Crewcab7.3, 96extccabsb, 96Powerstrokin, 97 F250 PS, 97-7.3powerstroke, 97-BIG RED, 97Beast, 97blackbetty, 97brute, 97CCLB410LS, 97dodgectd, 97Stroker13, 97supercab, 97tanpowerstroke, 97_Stroker, All Jacked Up, amscontr, Arlogger, ashman148, Ausm7499, aussie powerstroke, baggedbug, BayRoan, Beeholder, beekers-customs, BIG E, big white7.3, Bigbibb, biggreen96, bigwheel, BigWhite97, billmoody1, bithead08, Blown284, bluesix, Blynch, bmorervns20, bnbdiesel83, boonman, Boost96, borncountry, Brandonwilk10, BRAVO, briggs60, bubbamcnasty, Buddy B, Bulldog, c con, caseyk, Cheapshot, chris horst, Clatterindiesel, cody342b, codypowerstroke, Conan4, corbread, cowboyoutlaw76, Cratos, cravin, cthom388, CURTIS250, d-selpowereddiebauer, dave96psd, davey99ps, davidamontoya, deezeljunky, dentexpowerstroke, Denver, Derailed, deweuy, Diesel Avenger, Dieseltron, dixiemudnut, dnlfluke, Dogmountain, Drew2010, dsinderson, earlybroncoboy, ep-98-z, EverettWV, excavator, ezygo, f250towrig, Flippincgfighter, Fordguy26, FORDRARI, Frenchb85, friskyjake, Gaius, gcasper, ghohouston, ghostang93, glovemeister, Grandmaspeedshop, Greger96obs, gsxr1216, heavyweight, helo1, hendricksbus, HOLMES, hotshoe91m, Houser04LLY, ifitssmokinitsstrokin, ike0321, iowawiley, Jbo2155, JCart, Jcavers, jcspowerstroke, jdneis, Jetfxr, JGod, JJBlack, jlray17, jmegt, jmontes, JMWRIGHT335, jrlax5, jrracerdad, jtsparks2, Jwagoner15, K5383, Kampy, kbmkviii, kcbhiw, Ken-olson, kowman, kpasichnyk, Ks94.5powerstroke, lght1, LiftedSuzuki, littlewoody, Load182, loudmouth, louisvanwilker, ltjag101, lwhaples, madpogue, matthew82, mean matt, Michael97, middlemanjw, Mike1996F350, mike1pat, mjonesjr, morefuel, Mpoage, mrbleegs, Mudbrother, mxredneck, NEBR99.5 OIL BURNER, neverkickn, NightTrain601, np205, old man dave, oldschoolstrokerr, outlaw 4017, OUTLAW-OFFROAD, OUTLAW101, Patrick Feeley, PatriotsWanted, Petro, pimp800, portlandareae28, power strokin, powerstrokeracing, powerstrokin97, procomp, prostock1, PSD 2004, PSD-BLACK-CLOUD, psd444, PSDEng, PsRumors, pumpkin, quadindad, rafter3w, rag-top_man, redmist, redpower, Richie, rndllquinn, rockytop, Rollncoal7.3, rolsmojave3, rsfvscott1, rummel, Rusty 92, Rusty-Ford, rusty1161, ryanlathey, salprofish, screagle07, Seawatch, sg465, shatukoal97, Shaun Lindmark, shaynep, Shovelhead79, shredder55, Silenpro, silent64, slonebuilt, SMOKE&STROKE, smokerollerjeremy, smokindiesel2, Sodbuster Jr., spectreblazer, speedy_fisher3, ssteve80, Stacks92, stoneykegonsa, Stroke-n-it, StrokeIt97, STROKER #1, strokernine6, strokertown, StrokerTurbo7.3, sunshinenukka1, swamp_ratt, ten speed, TERRCO, texascadillac42, the7.3dude, ThePanther, Thinbluelinetx, threestud, Thunderhawk6630, Tom S, toolmangary, tughill283, turboaz2, twelch3, tysonxj, vanderchevy18, wa96stroke, wes lewis, WidowMaker, woodduck97, Zai Luke ll, zhudgens, zilla68, zman700
You may not post new threads
You may not post replies
Forum Jump
